Luv2Q
Topic: Bearing Service 2015 178 Posted: 13 May 2015 at 11:34pm |
Really nice write-up, Cliff. I hadn't seen it earlier. Good job.
John & Teri
Tundra 5.7L V8 / RP 180
Podster
Posted: 15 May 2015 at 12:04am |
Thanks John! Yep, thought I would go ahead and get that first service out of the way!
Cliff & Raelynn
Ranger 4.0/178
Marx
Posted: 17 May 2015 at 1:50pm |
Good write up, I'm getting ready to tackle mine soon as our POD is due for it's annual. More importantly we are getting ready in a month and a half to move cross country 17 hour trip so I want to go through it personally. Thanks for the post!
2014 R-POD 177
Podster
Posted: 17 May 2015 at 3:57pm |
Thank you Sir, and good luck!
Cliff & Raelynn
Ranger 4.0/178
Guests
Posted: 18 May 2015 at 6:58am |
Nice job, Podster!
Podster
Posted: 18 May 2015 at 11:24pm |
Thank you Sir, keep your eye on those bearings and brakes...
Cliff & Raelynn
Ranger 4.0/178
podrunner
Posted: 19 May 2015 at 12:49pm |
This has been an interesting topic, but I still have an unanswered question. With the ez lube system, how often should grease be added and how much? As codycountry stated, what is the point of the ez lube if you repack every year? My pod is 5 years old, I have not repacked the bearings or used the ez lube. My previous trailer was a pop up. After about 5 years I did repack the bearings myself and I found that there was still plenty of grease on the bearings and the grease appeared to still be doing a good job. I do have a 500 mile trip this weekend and feel like I might use the ez lube..so for any of you who are using ez lube how often and how much grease? Thanks for all the good info.
2010 R Pod 151
2017 4runner
2006 Honda Metropolitan
Podster
Posted: 19 May 2015 at 1:36pm |
The point of the EZ Lube is provide an option not a replacement to the breakdown and repack. How that option is used is entirely up to the owner. Personally, I would not be comfortable not touching the bearings for 5 years. This link should take you to the EZ-Lube procedures...Good luck and safe travels Sir.
Cliff & Raelynn
Ranger 4.0/178
Luv2Q
Posted: 19 May 2015 at 2:39pm |
Since this is just discussion, I'd like to volunteer a query or two (keeping in mind that I'm no expert on bearing maintenance).
Podrunner, the mechanic's assertion that the biggest problem with the EZ-LUBE process is that people over-grease the bearings doesn't make sense to me. If the seals are good, you should be able to pump a barrel full of grease into the bearings and it would come right back out the exit galleys. As I say, it's a big "if": IF the seals are good ...
To me, the benefits of manually repacking are that (a) you don't have to worry about the leaking seal problem (you're gonna replace the seals anyway) and (b) you have a certain amount of peace of mind (if you aren't second-guessing yourself wondering if you did a good job) and (c) you get to clean & thoroughly inspect the bearings & races.
Once in a while, I get in a mood to go do something like a bearing repack. If I haven't gone a lot of miles and/or don't have a big cross-country trip on the horizon, it's nice to know the EZ-LUBE option is there if I'm not in a repack mood.
John & Teri
Podster
Posted: 03 Apr 2017 at 10:18pm |
Originally posted by fwunder
That really is a great and detailed description, Poster! Thanks.
Not sure what kind of milage/time this is recommended. I've got 10K+ miles on my 178 over the last year and don't feel an urgent need to do anything. Should I?
fred |
Fred! I reread this thread and just realized I missed your post.
Thanks! The manufacture recommends service at 12,000 miles or 12 months.
Have you done a bearing service to date?
Cliff & Raelynn
Ranger 4.0/178
