David and Danette
Calendar Event: surge protector Posted: 07 Apr 2015 at 1:39pm |
It sounds like you may have a better understanding of it than I did when I first installed my surge protector. If you have questions ask, better to be safe than sorry, not that I think your are going to have a problem but I like to be cautious. CharlieM and others were helpful in answering my questions.
2014 Ram 1500 Quad cab
Abbagail54
Posted: 10 Apr 2015 at 1:35pm |
Okay working on it, how can I tell which wires are going to shore and which ones are going to the rv?
Posted: 10 Apr 2015 at 2:35pm |
I posted to your question over on FB.. you are in the wrong place. Put that back together. You need to cut into the ORANGE wire. There is only one, and it runs from the shore power connector to the power distribution box.
David and Danette
Posted: 10 Apr 2015 at 7:43pm |
It is possible to remove the power inlet on the outside of the r-pod where the shore power connects and then trace that wire. That is the wire that connects to the surge protector. The threads were stripped on mine and I replaced it with a new one, its only four screws that secure it to the side of the camper. There is a rubber gasket that may stick but the power inlet should easily come free from the camper and there will be your wire. After wire is located screw power inlet back onto the camper. I hope this doesn't confuse you but thought it may help. I am sure furpod will be of great help too, and give you good directions.
Marx
Posted: 20 Jun 2015 at 5:57pm |
Originally posted by furpod
Yes you need a 30amp. What features you want/need will determine the model.
I have, and a lot of others have, the Progressive Industries HC30C hard wired with remote. It protects against low and high voltage, bad grounds, reverse polarity, mismatched cycles, and of course, surge. You may or may not feel you need all that. Many are happy with just a pedestal mounted surge only box.
How big of a headache is it to install one of them fancy "hard wired" thingamabobs? |
Sort of depends on floor plan, and where you have to put it, took me about 15 minutes. But it's very easy on a 177.
I think many with 178's have chosen to put them under the slide. I am sure there is room behind the converter and distribution panel on a 178, but have never had the opportunity to look..
This was a huge help. I did this early this morning and the extreme humidity and hot weather wiped me out for the rest of the day. Anyways found a youtube vid that should help answer any other questions. This should probably be a sticky or part of the instruction section. https://youtu.be/D9pqo3nqHcE
2014 R-POD 177
desert-wiggy
Posted: 12 Jan 2017 at 5:22pm |
Good afternoon Poddies.....I have 2015 179 has anyone hard wired a surge protector on this model? if so where did you access and mount. S
Posted: 12 Jan 2017 at 6:31pm |
Larry,
I have a 178 and a CAMCO surge protector from etrailer, 30 amp. Attaches to power stand-off. Warns for over and under voltage conditions. The 178, while not impossible does not have the accessibility to the wiring and power areas that other Pods have. I have done some wiring mods, like a 12 volt lighter socket with USB and gauge. Not as much area to work with as it is in forward shower wall where tele is. The 179 is sweet and fairly accessible.
TEDDY
Posted: 31 Oct 2017 at 2:47pm |
I'm going with a pedestal mount - will use a keyed bicycle chain wrapped around the protector and pedestal. That should give the casual kleptomaniac pause. Nothing will stop a determined thief.
Teddy
