  New Posts New Posts RSS Feed: Fresh water fills from city water
Topic ClosedFresh water fills from city water
bonanddoug View Drop Down
Direct Link To This Post Topic: Fresh water fills from city water
    Posted: 18 Nov 2014 at 7:01pm
We had this happen one time at a KOA.  We were hooked up to the city water connection and found water coming out of the fresh water fill fitting.  This only happened once and we used water hookups since without our tank getting filled.  Yes we do use a pressure regulator.
2015 179 HRE
2014 Chevy Silverado 1500
Direct Link To This Post Posted: 18 Nov 2014 at 7:21pm
There is a one way valve built into the front of the pump, they sometimes get stuck, or fail. Try cycling your pump on and off a few times, see if that clears it. Disconnect from city water when you do it, so it gets flow..
pepmac View Drop Down
Direct Link To This Post Posted: 18 Dec 2014 at 6:44pm
We had the same problem and took it in to service .. Plastic was stuck on valve keeping it from working.
kymooses View Drop Down
Direct Link To This Post Posted: 18 Dec 2014 at 7:03pm
Thumbs Up
