  New Posts New Posts RSS Feed: Nov Scotia
Topic ClosedNov Scotia
Seanl View Drop Down
Direct Link To This Post Topic: Nov Scotia
    Posted: 01 Aug 2014 at 10:51am
Originally posted by grandma20
Thanks so much. We are getting there. We are walmart camping in Moncontin (sp). On our way .to Cabot trail. It is taking us longer to get there than I thought. We came from Dubuque,Iowa. And have been on the road for 9days so far. About how long does the Cabot trail take ?  Thanks for your information. Judy
I think you mean Moncton or as I llike to call it Monkey town.
Harry View Drop Down
Direct Link To This Post Posted: 01 Aug 2014 at 9:58am
Hi Judy.
As with any place, it depends on how much you want to see along the way.  If you use Nova Scotia's 100 series highways, you bypass a lot of the small communities and miss a lot of what the Province has to offer.  Assuming this, starting at Amherst on the New Brunswick/Nova Scotia border, allow about four hours to drive across Mainland Nova Scotia to the Canso Causeway, which is the link to Cape Breton.  You can also us the old Route 6, which runs along the Northumberland shore, but that takes much longer.  Far more scenic, though.
Option 1:
At the end of the causeway, you can choose to do what the locals call the "long trail", which is to go up the north west side of Cape Breton through Port Hood, Inverness, and Cheticamp, (allow two or three hours for this).  You have a very good option here of camping in Highlands National Park ( see my previous posting).  From this point you actually enter the Trail, which is a more or less circular route which terminates on Highway 105 in Baddeck.  Allow a full day for this part of the trip.  There are plenty of hills, many switchback turns, and fabulous look-offs.  If you are returning homeward at this point, head back to Mainland NS via the 105, which is quicker and still quite picturesque.
Option 2:
At the end of the causeway,  head directly toward Sydney on the 105.  About an hour or so later make a left turn (it's well marked) and go along the Margaree River.  This is a fabulously beautiful area.  It will take you to Cheticamp, and then go around the Trail as in Option 1, terminating at Baddeck on the 105.
Option 3:
Start off the same as in Option 2, but drive by the Marahree turn-off, but turn left about twenty minutes later at Baddeck.  This will take you around the Trail toward Cheticamp, but in the reverse direction.  When I lived in that area (Sydney), people favoured this route less than Option 1 or 2 because there are more left turns.  You are on the "outside" of the turns more often, therefore are closer to the edge more often.  Frankly, I didn't see much of a difference, because there are simply a lot of turns, and speeds don't get up very high anywhere along the trail.  That said, the Trail is well maintained, fully paved, and guard rails are anywhere there is any danger, so it is a very good road.
Make sure your TV is in good working order (cooling, brakes), and the brakes on your 'pod are good.  I'd set them up a bit "stronger", using the control, when I entered the Trail, though.  Have your camera ready with lots of memory on it.  There are plenty of gas stations (expect the gas price to run a bit higher in this neck of the woods) along the way, so that's not an issue.  I would also limit the amount of water I carry on board as well to keep the weight as low as possible.
Those three options assume you will tow your 'pod the whole way.
Here's what I did three years ago (towing a pop-up).
I started as in Option 2' and camped that night in the National Park in Cheticamp.  I left the camper there, and drove around the trail.  I returned to Cheticamp by going up the Margaree.  The next day we returned to Mainland NS by heading back down the coast through Port Hood to the Canso Causeway.  This way we saw everything we could.
Of course, follow what I'm saying on a map, and you'll see the choices that are available more clearly.
I've driven the Trail with and without a trailer, and I far prefer leaving the trailer behind for this particular drive.
Whew... that's about the best I can do from memory.
2013 R-pod 176T
TV: 2013 Honda Ridgeline
3.5 L 4WD
Budward View Drop Down
Direct Link To This Post Posted: 01 Aug 2014 at 6:42am
Just be aware you need passports now to transition the Canada/US border.   That wasn't the case last time I went.
2014 179
grandma20 View Drop Down
Direct Link To This Post Posted: 01 Aug 2014 at 6:31am
Judy
Direct Link To This Post Posted: 31 Jul 2014 at 7:48pm
I've been a resident of Nova Scotia since 1970; I guess that makes it 44 years.  Part of that time I lived in Sydney, near the Cabot Trail.  That is a must-see, especially near the end of September, when the fall leaves are at their height.  Most campgrounds are open through that period, but check ahead just to be sure.  We have stayed at The Highlands National Park in Cheticamp (highly recommended). Most campgrounds in the province remain open until Canadian Thanksgiving, the second Monday in October, the same as Columbus Day in the US.
 Three things to be careful of if you're traveling in Cape Breton in late September:
1.  Moose are everywhere, and are a real threat, especially in the evenings.  A moose hit at any speed will do a lot of damage and cause some serious injuries.
2.  Be prepared for chilly night time temperatures.  Take the frost warnings seriously.
3.  Cheticamp, which is in Northern Cape Breton, is subject to Les Suêtes winds, which can gust as high as 125 mph in the aftermath of large storms.  If these winds are forecast, stay put.
That said, the Trail is well worth the visit.
Once in Nova Scotia, expect fairly hilly and windy driving conditions.  It's not a place where one can tow economically.  Gasoline today is running $1.34/liter.  Multiply that by 4 (since there are almost exactly 4 litres in a US gallon), make the differential adjustment between the US and Canadian Dollar, and you will pay very close to $5.00 US a gallon.
I now live in Bridgewater, which is on the Lighthouse Route, and there are many many small communities and places to see along the Nova Scotia South Shore (the "old" route from Halifax to Yarmouth - Hwy 3).  My favourite place, Blue Rocks, is only 20 minutes from my home and seems to be a microcosm of all that Nova Scotia offers:  rugged beauty, peace, quiet, quaint buildings, and friendly people.
We have found a particularly charming little campground, Fisherman's Cove RV & Campground, which, for us, is less than an hour away.  It is in Hunt's Point, about 20 minutes south of Liverpool N.S.  The sites are random-shaped, yet private.  There is no "parking lot" arrangement.  The owners are very friendly and accomodating, and the facilities are spotless.  There are many other very good places in the province as well.
 I am not a fan of the NS provincial parks, since none of them have serviced sites.  They do have very good washroom facilities, water and dumping stations, but, other than that, you are camping dry.  The good news is that they are in prime areas:  Graves Island (near Chester), Thomas Riddel (near Liverpool), and Risser's Beach (near Petite Rivière) are three very popular parks, and they offer different experiences and vistas.  There are many more in other parts of the province.
After a few years with no ferry running between Maine and Yarmouth, one has resumed this year between Yarmouth and Portland, Maine.  Be prepared to pay a lot of money, though.  A return trip with two adults and a 'pod in back will likely run in the area of $800.00, and more if you wish to book a cabin  And embarking, travelling, and disembarking can occupy up to 14 hours.   Instead, you might enjoy taking your time and camp through Maine and New Brunswick on your way to Nova Scotia.  Time on the road from Boston to my home in Bridgewater is 13 hours one way (we do this often), so you won't really gain any time by taking the ferry.  You certainly won't save any money.  Of course, the cruise itself is often seen as part of the enjoyment.  Look up Nova Star Cruises for details about schedules, and costs for taking your 'pod.
If you are thinking of visiting Nova Scotia, just ask on this forum, and I will answer what I can as honestly as I can.  I'm not known for sugar-coating things.  I can say that you will have a wonderful time, meet wonderful and peaceful people, and will never forget it.
Happy camping, and we might even meet!
2013 R-pod 176T
3.5 L 4WD
Direct Link To This Post Posted: 25 Jul 2014 at 5:56pm
OK! Now this is on our bucket list!
Thanks!
Gonna need a bigger bucket...
Pod People View Drop Down
Direct Link To This Post Posted: 18 Jul 2014 at 4:56pm
We traveled to Nova Scotia before we had our Pod.  the thing that I remember was that everything seemed to close down Oct.1.  check before you go if you are planning to be there in the fall/early winter.  We were able to catch the tide change (12'+/-) at Bay of Fundy near St. John's.
We followed the Lighthouse Route, the Cabot Trail and returned from Yarmouth to Bar Harbor, Maine via ferry.
Nova Scotia reminded me of rural USA in the mid 50's-much less lights, developement and traffic.  a beautiful area with scenic places everywhere.  Friendly people and reasonable prices.
Enjoy the trip
Vann
Vann & Laura 2015 RPod 179
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 17 Jul 2014 at 7:27pm
I have never enjoyed a vacation more than our Nova Scotia trip.  I hope to visit again some day.
2011 R-Pod 177
2010 Ford F-150
CaperPodder View Drop Down
Direct Link To This Post Posted: 17 Jul 2014 at 8:08am
I second Seanl's suggestion. If you're coming to Nova Scotia, make sure to travel the Cabot Trail. Cape Breton Highlands National Park has 2 campgrounds, one on the west side and one on the east side. Cheticamp is the one on the western side and Broad Cove is the one on the eastern side.
Most of the Provincial parks are really good although some are more popular than others and require reservations in advance if you hope to get a spot.
Let me know if you want or need more information on Nova Scotia.
Don, Mimi, & Nola the Goldendoodle
2013 RPod 177 (CachePod)
2013 F-150 4x4
Direct Link To This Post Posted: 15 Jul 2014 at 7:35pm
We stayed for a couple of days at a commercial campground near Digby, and I can't recall the name.  We also stayed at a beautiful provincial park, and I am not sure but I think it was Thomas Raddall park.  We were there in the middle of June and almost alone in the park.  It was fantastic.  What a beautiful province.
2011 R-Pod 177
2010 Ford F-150
