  New Posts New Posts RSS Feed: 12 volt out lets
Topic Closed12 volt out lets
CharlieM View Drop Down
Direct Link To This Post Topic: 12 volt out lets
    Posted: 08 May 2014 at 9:23pm
I agree and I did run #10 for my added outlets, but I'm a stickler and I've learned to work with #10. Most devices used by campers don't pull 15A so I've suggested #12. That said I agree #10 is better especially for longer runs. It's just harder to run and may be overkill for iPads, lights, fans, etc.
Camp on................
cody91 View Drop Down
Direct Link To This Post Posted: 08 May 2014 at 9:41pm
[QUOTE=CharlieM]Use #12 AWG wire to minimize voltage drop to the added sockets. Use a 15 amp fuse. A 20A fuse would protect #12 wire, but most 12V sockets are rated at 15A or less. Therefore I suggest a 15 Amp fuse. With this configuration each individual socket can supply 15A but the total of the two cannot exceed 15A. Clear as mud?[/QUOTE]
Crystal clear.  I was already planning to use 12 gauge wire and a 15A fuse for a single run to the converter box.  I don't think I'll be running much through each line (Ipad, garmin GPS watch, etc.) and will rarely use both at the same time.
Thanks,
Direct Link To This Post Posted: 09 May 2014 at 3:56pm
I'm trying to find the best places to mount two 12 VDC outlets in R178.  Anyone have any suggestions?
Direct Link To This Post Posted: 09 May 2014 at 4:05pm
Ya know cody, I would probably go camping a time or two first. I put my first one right next to the WFCO panel cuz it was easy an made sense for charging phones and small inverter for TV. I bought a 12v. 6 foot extension and went camping.
I soon learned that I (we) wanted another back by the bed for a reading light or CPAP and another under the dinette for the same. Some folks want one in the counter area for the margarita blender. I think it's more a personal decision than a technical one.
Direct Link To This Post Posted: 09 May 2014 at 4:26pm
Fred,
Thanks for the response.  Just trying to gather some insight from those who've gone there before me.  I'm also thinking about that panel to the right of the converter box.  Seems like an easy distance and no wire fishing would be necessary.  I'm think about sometimes putting that plug-in battery monitor someone mentioned a while back so I thought near the converter box may be too low.
Direct Link To This Post Posted: 09 May 2014 at 4:36pm
Cody, my WFCO solution was the following. Yeah, it's a little low for the plug-in voltmeter, but not horrible. I did install a voltmeter up top, but it takes a bit more work sawing and drilling and cutting and wire fishing.
You could put your 12v. outlet up top in the 178 on either side of the stereo. It's an easy drop to the panel from there. Just didn't seem convenient to me.
Direct Link To This Post Posted: 09 May 2014 at 9:40pm
Fred,
That's a pretty cool voltmeter.  I think I'm going to put the my plug around the same spot you placed yours.
Thanks,
Cody
Direct Link To This Post Posted: 10 May 2014 at 8:49am
This is a 177.. almost exactly the same floorplan as a 178:
front bench, next to the power center..
next to the bed, there is a little "shelf" next to the bed when the slide is out, just perfect for a phone to sit on:
kylekai View Drop Down
Direct Link To This Post Posted: 09 Sep 2014 at 1:29pm
I have a 179, and it has a U shaped dinette.  Under the rear portion of the seat are a lot of wires.  Can any of those be used for a 12 volt power outlet?
Webstas View Drop Down
Direct Link To This Post Posted: 09 Sep 2014 at 2:02pm
anyone know the model number off the WFCO converters that are in our pods?
is it the 35 amp Power Center?
http://www.wfcoelectronics.com/UI/Power-Centers-WF-8935ANP.aspx?ptype=3&pid=11
