strorg
Topic: Jeep Liberty Hitch Posted: 02 Dec 2013 at 11:05am |
TV is a Jeep Liberty with factory towing package. My problem is that the hitch requires a couple of inches of drop in order to have enough clearance for the ball and the tongue of the trailer on my 178. This results in the tongue being about 4-6 inches below level. Any other Liberty owners out there that have solved this?
Thanks...Tom
Tom and Tracy
Mobile, AL
2014 RP-178
Kokopod
Posted: 02 Dec 2013 at 11:20am |
Go to etrailer.com and look up adjustable receiver shanks. They come in 4 6 8 10 inch drops. Our Liberty used a 4 inch, but our trailer is a Hood River Edition. You may need an 8. These can be adjusted also by tilting the ball to make up the inch differences. In other words, the shanks jump by 2 inches, but you can add or subtract the 1 inch with the tilt. Jeep requires an equalizer hitch to reach its 5,000 lb tow capacity. Otherwise it comes up short for the Rpod.
2017 Jayco Melbourne 24k
2013 Premier 19FBPR
Formerly-2013 R-pod 177HRE
2011 Dodge Durango
Love a good road trip
Posted: 02 Dec 2013 at 12:36pm |
You are wanting to RAISE the tongue when hooked up? If so use a drop ball mount and turn it over.
http://www.etrailer.com/dept-pg-Ball_Mounts-hs-Fits_2_Inch_Hitch.aspx
rpodcamper.com
Posted: 02 Dec 2013 at 12:42pm |
when I had a Jeep Liberty I had to get a longer hitch to go past the spare tire on the jeep. I had a straight bar and that was level with my 2009 R-pod 171 with no risers on it.
strorg
Posted: 02 Dec 2013 at 12:47pm |
I think this will work. The key is the longer shank, which moves the ball out past the spare tire and allows me to turn it over to get the rise i need.
Tom and Tracy
Mobile, AL
2014 RP-178
Seanl
Posted: 02 Dec 2013 at 1:05pm |
I get tha you need a longer bar but why do you need a rise. The liberty Hitch should he higher than the tongue of the Trailer when the trailer is level.
strorg
Posted: 02 Dec 2013 at 1:16pm |
My Liberty is 2002 model, and my Pod has the riser kit installed. I need 2-3" of rise to level it, and with the lack of clearance between the tire and the ball, I currently use a 3" drop.
Not sure if the difference is my older model Jeep or the riser kit.
Tom and Tracy
Mobile, AL
2014 RP-178
Capt. Irk
Posted: 02 Dec 2013 at 6:21pm |
I have a 2007 Liberty and a Hood River 176 (with factory risers). I do not use a drop nor riser....
2013 176HRE / 2017 Ram 1500
kellyandkelly
Posted: 28 Mar 2015 at 7:59pm |
Hi, so any of you that are towing an r-pod with a jeep liberty have any trouble at all? I just bought one and it's swayin g all over the place. I am going to get a weight distrib. system this week, which hopefully will solve the problem. I read conflicting info so any insight is welcome! The jeep should be able to tow just fine, but would like to confirm.
Posted: 28 Mar 2015 at 8:43pm |
There is a lot to sway.. what's your tongue weight? Is the Pod sitting level when hooked up and on level ground, or just a bit nose down? What speed were you towing at? Tire pressure on the pod (should be 50psi)?Tanks empty?.. What hitch are you using?
