  New Posts New Posts RSS Feed: Anderson WDH and Prodigy 3 brake controller
Topic ClosedAnderson WDH and Prodigy 3 brake controller
Fj View Drop Down
Direct Link To This Post Topic: Anderson WDH and Prodigy 3 brake controller
    Posted: 25 Oct 2013 at 12:28am
Hi, I am looking for advice on getting my TV ,2007 Toyota Fj, ready to pick up our 177 HRE from the dealer.   I am interested in the Anderson WDH and the Prodigy 3 brake controller.   If anyone has any information or other suggestion I would appreciate it
2013 R pod 177 HRE
07 Toyota Fj
Lefty View Drop Down
Direct Link To This Post Posted: 25 Oct 2013 at 7:54am
I have the P3 and think it's great. I also have the Equalizer WDH. My TV is a 07 4Runner , so we have similar vehicles.
Fj View Drop Down
Direct Link To This Post Posted: 25 Oct 2013 at 6:13pm
Thanks,  May end up with the Equalizer WDH.   The Anderson looked light weight, no noise or ball grease.  But would like to hear from some pod owners that have used it.
2013 R pod 177 HRE
07 Toyota Fj
danthoman View Drop Down
Direct Link To This Post Posted: 26 Oct 2013 at 12:35pm
I have the andersen wdh an think it works great. The deciding factor for me between the andersen and equalizer was the ease of installation of the andersen. It took me about 30 minutes to install. Now it takes only a few minutes to be up and running. Put the hitch in the receiver, hook up the trailer and tighten the chains with the supplied socket and you're good to go. I don't remember which prodigy I have but it also works very well. I have a tacoma with the trailer package and the controller hooked directly into the wiring harness. No extra wiring was necessary.
Linda and Dan
Calley the golden retriever
R-pod 177 and a Tundra 8 cyl
Fj View Drop Down
Direct Link To This Post Posted: 26 Oct 2013 at 1:22pm
Thanks for the info.
I have the tow package on my Fj so I should have the wiring harness up front to plug in the Prodigy.  I only have a flat 4 pin connector at the hitch.   Did you have to run the brake wire to the hitch or is there a plug for an adaptor at the rear of the vehicle also?  Do the Pods use a round 7 pin connector?
2013 R pod 177 HRE
07 Toyota Fj
Direct Link To This Post Posted: 26 Oct 2013 at 1:41pm
You will need the round 7 pin combo brake and light connection. Your dealer should be able to install it for you. Not cheap. I love the Equalizer wdh and find it easy to hook up. It is heavy duty but I like that. My dealer installed it for me when I picked up the 178.
Direct Link To This Post Posted: 26 Oct 2013 at 2:50pm
When I first picked up my pod I used a 7 pin to 4 pin because that's what was on my old xterra. The new tacoma already had the 7 pin connector installed as part of the tow package. My old tacoma '09 had just the 4 pin connector and would have required the installation of the seven pin with all the associated extra wiring for the battery and brake controller. My toyota dealer would not do the installation.
You might look into the prodigy wireless brake controller. That, I think, would only require the 4 pin connector. However, with a 4 pin connector there would be no battery feed from your TV to the pod. Not a real problem in most cases. The pod battery should be able to run the fridge for a day.
The andersen hitch is rated for 14,000 pounds, so it is heavy duty.
Linda and Dan
Direct Link To This Post Posted: 26 Oct 2013 at 3:14pm
   I was on the Lance owners forum and there were several using the Anderson hitch and were very happy with it. I think the hitch is becoming very popular some dealers have not been able to keep it in stock. I think it would be a good choice. Have not tried it myself so I am unable to compare it to the Equalizer that we are using now. But if I were to buy a new hitch the Anderson could be the one I would chose.     David
2014 Ram 1500 Quad cab
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 26 Oct 2013 at 6:20pm
I have a 2010 FJ.  I'm not sure what you mean by a tow package.  Mine came with the wires run to the back for a 4-pin connector but I had to install the actual plug. 4-pin connectors don't have a brake pin, so yes, you will have to do some slightly fancy wiring to get a brake wire to the back and yes, pods do use a 7-pin Bargeman connector.
I have a 2010 176 Rpod and have put around 3000 miles on it with no weight distributing hitch and no hint of why I'd need one.  I do highly recommend hooking up the brakes though. I have a Tekonsha Primus IQ controller and am quite happy with it.  It's work flawlessly, but what I like most about it is it makes the trailer brakes work.  I've pulled a lot of trailers without brakes and was used to the stress and caution.  Trailer brakes really take a load of your mind.  I'm sure a WDH might do the same, but I just haven't seen it yet.
TT
FJ Cruiser
Fj View Drop Down
Direct Link To This Post Posted: 27 Oct 2013 at 1:41am
Thank you all for the help and suggestions.  It is appreciated.
2013 R pod 177 HRE
07 Toyota Fj
