asreichler
Topic: Tire changing Posted: 14 Sep 2013 at 12:26am |
What is the best way to lift the R Pod to change a flat tire?
2014 178 TV 2004 Dodge 2500 deisel
Sleepless
Posted: 14 Sep 2013 at 12:51pm |
I have not had to change a tire, but had to jack it up when I installed my riser kit. Per the instructions, I placed the jack under the frame, just behind the wheel.
Bob
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche
Leo B
Posted: 14 Sep 2013 at 1:29pm |
We have also had to jack up our 171 once and used a small floor jack on the frame just behind the wheel. Worked well.
TIDALWAVE
Posted: 14 Sep 2013 at 3:54pm |
The Lippert axle has two vertical splines on the rear side of the axle just inboard of the hub. The jack should use these splines for lifting the axle. Don't lift the axle on the round tube portion!
TIDALWAVE
asreichler
Posted: 16 Sep 2013 at 7:06pm |
Thanks for the info. Any suggestions for what type of jack to carry while traveling. Allen
Sleepless
Posted: 16 Sep 2013 at 7:17pm |
The scissors jack for my TV works great. A small floor jack might be better, but takes up valuable storage space.
Bob
dsmiths
Posted: 16 Sep 2013 at 8:57pm |
I studied the jack problem and came to the conclusion that my factory jack in the Trailblazer will work perfectly if need and then I was able to remove a 20 lb hydraulic jack in the rear garage and save that much more weight. hopefully I will not have to use it.
Dane and Donna Smith
2011 RP-172
lift kit
Keith-N-Dar
Posted: 16 Sep 2013 at 9:56pm |
I have a hydraulic bottle jack with me in the TV all the time anyway, so I expect that is what I will use if I need to.
Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
asreichler
Posted: 17 Sep 2013 at 1:24am |
Thanks everyone Allen
wallawallaron
Posted: 17 Sep 2013 at 8:26am |
Just on a side note.
Might want to make sure your TV jack will raise the POD enough. You MAY have to carry some pieces of 2x6 for added lift. WWR
WallaWallaron,2012 RP177 H.R.E.,2010 F-150.NRA Life Member
9/11 Never Forget
