  New Posts New Posts RSS Feed: refrigerator flasjong
Topic Closedrefrigerator flasjong
21grandma View Drop Down
Direct Link To This Post Topic: refrigerator flasjong
    Posted: 28 Jun 2013 at 11:36pm
SmileReset GFCI and works fine.
21grandma
CharlieM View Drop Down
Direct Link To This Post Posted: 26 Jun 2013 at 10:06pm
Reset by pressing and holding the MODE button until all lights go off. Then press MODE until the AC light is lit.
Direct Link To This Post Posted: 26 Jun 2013 at 10:05pm
How do I reset it?  Instruction manual is vague.
21grandma
Direct Link To This Post Posted: 26 Jun 2013 at 10:03pm
needs to be reset. or, it's broken.
To reset it, you need to disconnect it from power, flip the breaker and pull the fuse. Or in your case, have someone do it for you.. or, disconnect the battery, and pull the plug from the wall..
But first try just turning it all the way off by holding the power button until it turns off.. then turn it on again and select 120v.
Direct Link To This Post Posted: 26 Jun 2013 at 9:59pm
SleepyWhy would the refrigerator LED failure indicater light be flashing when in the electric mods?  The pod is plugged into the electricity in our garage.
21grandma
