  New Posts New Posts RSS Feed: 2012 Rpod 177 problems
Topic Closed2012 Rpod 177 problems
 Post Reply Post Reply Page  123 5>
dshearer View Drop Down
Direct Link To This Post Topic: 2012 Rpod 177 problems
    Posted: 17 Jun 2013 at 4:03pm
Unfortunately, the latest in a line of problems with our 177 is the axle failure which will cost about $900.00, waiting 6-7 weeks for the part, and not covered by warranty. We are extremely disappointed. Other issues have been: rear window leak, DVD falling off cabinet numerous times, lights falling off ceiling, lose clamp under slide-out (clap pushing on slide-out facia causing it to catch the screws), loose wiring on monitor panel for black and grey tanks (tanks not reading properly), furnace grill continues to fall off when traveling, table rubs the front camper wall, sink was not tightened down and moved out of position, and screws fell out of brackets holding dump valves.
I'm sure some might wonder how we care for our camper, it's our first new camp trailer and we are extremely careful with it.
Anyone else having similar issues?
Montana camper
Seanl View Drop Down
Direct Link To This Post Posted: 17 Jun 2013 at 5:08pm
Nope I had an issue with the Ac that was repaired under warranty and thats it.
danthoman View Drop Down
Direct Link To This Post Posted: 17 Jun 2013 at 5:11pm
Wow, we haven't had any problems like that. Everything has worked fine except for the black water tank monitor and connecting a hose (not a drinking water hose) to the spray inlet to help clean the tank when emptying solved that. Most all the problems mentioned should have been fixed under warranty.
Also, welcome to forum.
Linda and Dan
Calley the golden retriever
R-pod 177 and a Tundra 8 cyl
Craneman View Drop Down
Direct Link To This Post Posted: 17 Jun 2013 at 5:15pm
Were these items covered by factory warrantee ?
               Moe
Jo and Gary
2010 174
2011 Ford 150
Goose View Drop Down
Direct Link To This Post Posted: 17 Jun 2013 at 5:29pm
That's sad to hear of all your problems. Do you travel with the table set up when you travel, this I could see rubbing the front wall. Goose
Direct Link To This Post Posted: 17 Jun 2013 at 7:16pm
Welcome.  What year is your pod?  Did you buy it from a dealer (new or used) or from another owner?
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 17 Jun 2013 at 7:36pm
Ours is a 2011 and has been nearly trouble free.  Ours was made in Indiana.  Was yours made out west?
2011 R-Pod 177
2010 Ford F-150
P&M View Drop Down
Direct Link To This Post Posted: 18 Jun 2013 at 11:52am
We've had one or two minor issues with ours since buying it last October, but nothing like what you have encountered.
P & M ... and Comet too!
2012 171 -- The Monkey Pod
2018 Ram 2500
hogone View Drop Down
Direct Link To This Post Posted: 18 Jun 2013 at 12:47pm
I have had no major issues as of yet, granted it's only a year old.  When I purchased, I did buy the extended warrenty.  Never in my life have I purchased an extended warrenty on anything, not quite sure why I did on the pod.  Maybe for piece of mind, but then how good is it actually if I were to use.  One thing I have noticed however is when my air conditioner compressor goes off there is kind of a thumping noise.
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Direct Link To This Post Posted: 18 Jun 2013 at 2:31pm
Thumping is normal, if you can call anything about the A/C normal.
I, too, never buy extended warranties but did for the pod.
