Several of you have posted modifications in which larger screen flat panel tv's have been mounted on
swing arms attached to the side of the 177's little media cabinet. One shows a removable bracket
installation which, I'm sure, aids in safe transport.
My question is- given a non-removable bracket installation, have you 'imagineered' any security measure
to make the flat panel more secure during transit?
Secondarily, I know that the torque forces on the cabinet side exceed anything engineered by FR,
so have you beefed up the cabinet mounting in any way? I'm thinking about some 'spiral' sheet rock
anchors in the ceiling material into which an L brace can be screwed, the other leg screwed into the cabinet
side.
We are fortunate to have several very imaginative mod-ers as Forum members. Any insight is welcome.
I found a low profile mount (2 piece) on the internet while searching on my specific flat panel TV. On piece is mounted directly on the front door (off-center toward the kitchen side of the camper) of the entertainment center and the other mounts direcly on the TV. Did the necessary wire splitting and added a power strip inside the entertainment center. TV just slides down over the mount on the entertainment center and is fully visible up front in the dinette area of the 177. One thing I did, just to be safe, was to reinforce the entertainment center mounts to the ceiling of the camper - - but those flat panel TV's really aren't that heavy. The one we have is 22-23" I think and is made by Haier.
MJ
