  New Posts New Posts RSS Feed: Service Recall - LP Tank Mounts
Topic ClosedService Recall - LP Tank Mounts
rpodadmin View Drop Down
Direct Link To This Post Topic: Service Recall - LP Tank Mounts
    Posted: 18 Feb 2009 at 3:30pm
Forest River has issued a service recall on the LP tank mount. Please see your local dealer for more information.
Edited by rpodAdmin - 18 Feb 2009 at 3:40pm
capringl View Drop Down
Direct Link To This Post Posted: 04 Mar 2009 at 4:00pm
If go to a local Forest River Dealer (that doesn't sell rpods) will they be able to pull this from Forest River and take care of this for me? Or should I print this out and take it in and show them?
Craig
R-Pod 172
2008 Jeep Wrangler Rubicon
Direct Link To This Post Posted: 04 Mar 2009 at 4:08pm
You will need to let the local dealer know of the repair code. In this case it is a couple of straps that need installed - you could call your dealer and they can send them to you. It is an easy retro fit.
Direct Link To This Post Posted: 04 Mar 2009 at 4:17pm
Here are photos of the recall installed...
Direct Link To This Post Posted: 14 Mar 2009 at 11:55am
There has to be a better way to fix this situation!  Any ideas?  Linda
Direct Link To This Post Posted: 17 Mar 2009 at 5:28pm
On the 171 I have ordered (Due to pickup at the end of the month) I'm having the dealer remove the single holder and they are installing a Dual Propane Holder for me.  They are also putting on a regulator that will control both bottles and I will be able to use 20 or 30 LB bottles.  The strap across the bottle IMHO just looks cheap.  Plus over time will dry rot and snap.
Direct Link To This Post Posted: 09 Jul 2009 at 11:12pm
Here is a pic of what we did with the tanks.
Direct Link To This Post Posted: 13 Jul 2009 at 3:02am
Our dealer put the strap over the vinyl cover of the single tank.  I wonder if I should put it over the tank instead, like above?
Direct Link To This Post Posted: 13 Jul 2009 at 1:11pm
Yes, the service bulletin calls for it to go over the tank directly.
Direct Link To This Post Posted: 28 Sep 2009 at 5:56pm
Hi folks.
We just got back today from our third trip with our 171. I went to pull the propane tank to have it filled and found that both the metal straps had broken (and been broken for some time judging by the corrosion on the surfaces of the break. Our R-pod had the nylon strap installed when we purchased it, however it obviously didn't prevent the metal strap from still failing.
This issue needs to be addressed immediately. The last trailer that Linda and I had a few years ago had a propane tank break loose on us and go under the trailer and punch a hole in the tank. Thank God it was on a secondary highway at the time, and that a spark didn't set off the propane that leaked out.
We had some other issues as well. I'll post a new thread on those.
Doug
