R-Pod Owners Forum Homepage
  New Posts New Posts RSS Feed: shower head
shower head
blissful View Drop Down
Post Options Post Options   Quote blissful Quote  Post ReplyReply Direct Link To This Post Topic: shower head
    Posted: 19 Feb 2012 at 3:22pm
Is it easy to replace the shower head?  If so, what kind should I use...not too expensive Cryand how to?
Blissful
dsmiths View Drop Down
Post Options Post Options   Quote dsmiths Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2012 at 4:03pm
Real simple, everything unscrews, I got the oxgenics from Camping world, I just put it on 2 weeks ago and have not had a chance to try it, several people on this post claim it gives better pressure and uses less water, fairly inexpensive and easy to install, I also ordered the chrome wall mount and was able to use one exsisting hole and cover the other with the new wall mount. very pretty shower head.
Dane and Donna Smith
2011 RP-172
lift kit
Hodge-PODge View Drop Down
Post Options Post Options   Quote Hodge-PODge Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 10:32am
Blissful
Many of us have replaced the R-Pod shower head and hose with the Oxygenics shower head, and count it as one of the best mods in our pods.  The Oxygenics shower head has a great spray even with low pressure.   It's very easy to swap both the shower head and the hose - you just unscrew the one that came with the R-Pod and screw the Oxygenics one in.  It comes in white or chrome. You can get it from Camping World or from Amazon.
http://www.campingworld.com/shopping/item/Oxygenics-Body-Spa-RV-Showerhead-White/38321/&
Diane
2011 RP 177, the Hodge-PODge
2011 Mercedes ML350
pentachris View Drop Down
Post Options Post Options   Quote pentachris Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 9:36pm
The Oxygenics shower head is great. Before you replace it, though, try removing the flow restrictor where the hose connects to the knob assembly. As you might guess from this picture and this picture, the increase in water pressure will be substantial.
Outbound View Drop Down
Post Options Post Options   Quote Outbound Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 11:04am
+1 for the Oxygenics shower head - its fantastic.  It has a variable flow control which helps to significantly cut down on the amount of water used in the shower.
Craig :: 2009 RP171 towed by a 2008 Mazda Tribute
Tri-Pod View Drop Down
Post Options Post Options   Quote Tri-Pod Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 4:13pm
This sounds like a great idea, I am going to order one now, does the current bracket hold the new head or do you have to switch that out also?
2013 SP 240 w outside kitchen
5.7L V8
Me, My Honey, and Max our GSP
secretbard View Drop Down
Post Options Post Options   Quote secretbard Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 5:53pm
It comes with a new bracket to hold the head.  I just replaced mine when I got the shower head.  It looks better too.  As far as the little Oring that holds the hose:  I left the old tan one on the wall.
2010 Rpod 172   :)
2004 Chevy Trailblazer
Damour View Drop Down
Post Options Post Options   Quote Damour Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2012 at 9:34pm
I bought the oxygenics but it's not installed yet
rp 171 , from Québec with not a good english writing lol
Post Options Post Options   Quote Outbound Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 5:15pm
Well, hurry up!  You'll love the oxygenics Big smile
Post Options Post Options   Quote Damour Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 10:08am
The temperatures still below zero at night ...
We will not go camping before the  month of may :)
