  New Posts New Posts RSS Feed: Can slide be operated manually?
JoRiley View Drop Down
Post Options Post Options   Quote JoRiley Quote  Post ReplyReply Direct Link To This Post Topic: Can slide be operated manually?
    Posted: 20 May 2025 at 1:48pm
I am a new owner of a used R-Pod.  I'm wondering if there is a way to operate the slide manually, in case the button doesn't work for some reason.
gpokluda View Drop Down
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2025 at 9:50pm
Not sure which model you have, but I had a 179 and one of the slide motors failed. The only way to open and close the slide is to remove the bolt that secures the slide motor to the body of the Rpod, slide the motor out of the way(has to be done on both sides of the slide) and pull the slide open and then push to close. There are a couple of YouTube videos with the step by step process.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Kawasaki KLR650
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2025 at 7:39pm
On my 2011 177 there is a process to follow, and quite laborious at that, but it can be done.  You Tube it.
