Rv antifreeze |
Vector1952 ![]() Groupie ![]() ![]() Joined: 28 Sep 2016 Location: RI Online Status: Offline Posts: 65 |
![]() ![]() ![]() ![]() Posted: 18 May 2025 at 10:47am |
Is it ok to leave rv antifreeze in lines during the summer
Xxxx7
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2709 |
If you're not using it, sure. Just be sure to flush it before you use it.
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3349 |
No issue with that as it is non toxic but the question is why? I only introduced rv antifreeze into the water lines once; never again as it took a few different concoctions to rid the lines of a nasty antifreeze taste (we use our fw tank for drinking water). For the last 13 years compressed air has been used to void the lines of water with no ill effects. A total of 16 oz. rv antifreeze is then used for the traps and a small amount for the top of the toilet to keep the seal moist throughout the winter months.
gpokluda ![]() Senior Member ![]() ![]() Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 399 |
+1 I used antifreeze in a previous RV and never again. I’ve been blowing out my lines for 10+ years with never an issue. Bit, answer your question, antifreeze in your lines for extended period of time will not affect them.
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Kawasaki KLR650 |
