batteries won't stay charged |
ronnieb ![]() Newbie ![]() Joined: 24 Oct 2020 Online Status: Offline Posts: 8 |
![]() ![]() ![]() ![]() Posted: Today at 10:00am |
My batteries won't stay charged after reaching 12 volts with a solar panel nor will they charge after driving. What to do?
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2704 |
What are you expecting? Batteries do self-discharge, even with no load. So expect to have to charge them at least once a month without a load.
Separate from that, there can be parasitic loads that will discharge a battery much more quickly. In extreme cases, maybe only a day or two. You need to use a DC-capable ammeter to see what parasitic load you have. The parasitic load on our RP179 is about 1/4 amp, or 250 milliamps.
Hi Glue Guy, I do charge the batteries every month, but on this last road trip, the batteries were at 7.6 volts after driving 10 hours..not enough to open the slide. I hade to start my truck to operate it.
Tars Tarkas ![]() Senior Member ![]() ![]() Joined: 14 Jan 2013 Location: Near Nashville Online Status: Offline Posts: 1453 |
How old is the battery? Are all cells filled with water? Are all connections clean and tight? TT
FJ Cruiser |
