furrion description |
JohnF ![]() Newbie ![]() Joined: 11 Apr 2025 Location: Idaho Online Status: Offline Posts: 3 |
![]() ![]() ![]() ![]() Posted: 12 Apr 2025 at 1:18pm |
Just got a 2020 R-pod 196 no documentation on TV connections or Furrion usage
![]() any info would be appreciated JohnF
John F
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6429 |
Not being sure of what Furrion unit is in your RPod, I would suggest getting the model information and doing a search for a manual.
This would be a good place to look: https://furrion.com/pages/downloads-audio-visual
mjlrpod ![]() Senior Member ![]() ![]() Joined: 27 Sep 2016 Location: Massachusetts Online Status: Offline Posts: 1221 |
The t.v. if i remember. is fairly simple. Ive changed models. I think you can watch just over the air t.v. with the campers antennea. On the remote, press menu, then choose air (i think). Then it will give you a choice to scan, it takes a minute, and it will look for any channels you can get. If you say hook up a fire stick to hdmi 1 (or hdmi 2 etc..) you go to menu, choose hdmi 1 (or 2 or 3) and it will bring up a list of apps you can use. You of course would need an internet hotspot of some sort. Good luck
2017.5 Rp-172
excellent thanks for the info
John F
that is what I needed thanks
John F
One additional thing is to remember to turn on the antenna booster (the button on the panel for the coaxial connection that goes to the TV). Be sure to turn it off as it will over time drain your battery if you are not using the trailer and it is in storage. Also, if you intend to use satellite TV and connect to the outside connection, turn the antenna booster off.
