  New Posts New Posts RSS Feed: Dewinterize 2021 R Pod  193
Jsappington0717 View Drop Down
Post Options Post Options   Quote Jsappington0717 Quote  Post ReplyReply Direct Link To This Post Topic: Dewinterize 2021 R Pod 193
    Posted: 18 Feb 2025 at 7:27am
Bought a 2021 RPod 193. It was winterized when I bought it in November. Can someone give me detailed instructions to dewinterize it. Should I drain the solution in gallon jugs. Thank you for any help.
J. Sap
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2025 at 8:12pm
Don't try to save the RV antifreeze. Just flush the lines. You will need to sanitize the water system anyway. Here is a hint. Use the advanced search function. It will allow you to search topics older than the default six months. There is a lot of information here but the default search won't necessarily find it. Advanced search is your friend.
GlueGuy View Drop Down
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2025 at 12:27pm
Better still, use Google search, which is way more sophisticated. You can tell Google search to restrict its lookup to a single web site by using the string site:rpod-owners.com in front of your search terms.
For a simple example about antifreeze and winterize you would enter:
site:rpod-owners.com antifreeze winterize
Google is your friend.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2025 at 12:35pm
Or in this case, site:rpod-owners.com dewinterize
and site:rpod-owners.com sanitize
Edited by StephenH - 19 Feb 2025 at 12:36pm
Post Options Post Options   Quote Jsappington0717 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2025 at 4:14pm
Is it ok to flush it on the ground or do I have to go to a dump station. Thank you for the imformation so far. Just wonder if it is toxic
J. Sap
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2025 at 5:05pm
I wouldn't drink RV antifreeze full strength, but there should not be all that much in the system. The outside shower, flush onto the ground. The sinks will go to your grey water tank, so you will need to dump that, preferably at a dump station. In NC it is not legal to dump grey water from a storage tank on the ground. It has to be treated as if it were from a black water tank.
