  New Posts New Posts RSS Feed: Fender mod
Topic ClosedFender mod
Direct Link To This Post Topic: Fender mod
    Posted: 20 Feb 2011 at 2:15pm
    I ran the positive wire across underneath the trailer along the axle using the existing zipties and adding some. The fenders I used for the ground. I spliced into the existing wire which ran under the trailer back to the tail lights. I used electrical tape and caulking for watertight connections. LED's are what I used they do not use much amps., you will not need to worry about overheating the existing wire if that is a need for concern.          David
2014 Ram 1500 Quad cab
TIDALWAVE View Drop Down
Direct Link To This Post Posted: 20 Feb 2011 at 9:17am
Several members have now shown their fender clearance lite mods.  It appears that the wiring is coming directly out of the Pod wall.  Where exactly did you tap into the present clearance lite wire(s)?
How did you cross the Pod floor to get the wiring from one side to the other...or did you tap into different wires on each side?
I have looked at my Pod to install fender lites but am still puzzled on where to tap and how to run the wires.
TIDALWAVE
Goose View Drop Down
Direct Link To This Post Posted: 19 Feb 2011 at 11:10am
Nice lights, they really look good. I have a longer mud flap that hangs down so it keeps stones, mud and spray off of the drain lines.     Goose.
Direct Link To This Post Posted: 19 Feb 2011 at 9:35am
