5 amp/day elec drain |
Post Reply | Page <123> |
Marvin
Groupie Joined: 21 Jan 2023 Location: Gig Harbor, WA Online Status: Offline Posts: 45 |
Topic: 5 amp/day elec drain Posted: 31 Jan 2024 at 12:44pm |
Ah yes... that was a suspect. How do I turn it off?
Marv
2019 RP178 Highly Modified 2022 Subaru Outback Wilderness Turbo Charger |
podders Helping podders - pHp Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Online Posts: 6290 |
Post Options Quote Reply Posted: 31 Jan 2024 at 1:26pm |
If yours is like mine, there is a little button on the wall plate where the coax connects. If there is a light showing, then it is turned on. Push the button and it should turn off.
Marvin
Post Options Quote Reply Posted: 31 Jan 2024 at 1:34pm |
Thank you. Its was off.
Back to the drawing Board.
Marv
Post Options Quote Reply Posted: 31 Jan 2024 at 1:54pm |
I would check that anyway. You can take the plate off and check the wires behind it to see if perhaps there is something going on there. It is better than to start cutting holes in the walls. |
Marvin
Post Options Quote Reply Posted: 31 Jan 2024 at 2:46pm |
Nope... to many cables going to it.
I also just discovered... the Bath fan is NOT on that circuit (the light is).. so the factory label is incorrect. So I need to trace those wires. Unless someone has a better idea. I have figured out a way to cut that panel out and the one above it and make it a door I can remove with 4 screws for each panel. I've had the RV power supply out... so I know the wiring in there... and need to start there again and see where # 4 goes. Any more ideas? One of these days I hope to post photos of all the Mods.
Marv
Post Options Quote Reply Posted: 31 Jan 2024 at 4:01pm |
Well, it is beyond my ability to do more than offer encouragement. It will be interesting to find out what the source of the drain is when you find it.
Marvin
Post Options Quote Reply Posted: 31 Jan 2024 at 5:43pm |
Thanks for trying to help.
Yes, it will be interesting when I find it.
Marv
Post Options Quote Reply Posted: 01 Feb 2024 at 10:07am |
There are a limited number of things that can be causing a drain like that. I would go to each device and disconnect them one at a time. If you have a clamp-on DC ammeter it would make isolating it a lot easier.
Marvin
Post Options Quote Reply Posted: 01 Feb 2024 at 10:42am |
Glue, great idea if I could get one in those tight impassable areas, and be able to see and read it. I have checked everything Known to be on that circuit but obviously there are some unknowns. There can't be that much on that Circuit which is why I'm considering making that panel a door so I can get access in there and solve a few mysteries and make a better command panel at the same time.
I've ordered a Endoscope
Inspection Camera with Articulation Head coming to look inside there and try and see where that wire goes or branches off to. I may never know, but if I pull the panel then I can cut the wire at branches and see what happens... then I can always add a switch to control it in the future. It least that's my current thinking. I'm also beginning to think the previous owner may have had this drain problem and unloaded it to the next owner... me. :-) |
Marv
James07
Newbie Joined: 19 Feb 2020 Location: Sacramento Online Status: Offline Posts: 19 |
Post Options Quote Reply Posted: 01 Feb 2024 at 11:34am |
I get a slight spark on the house 110v outlet whenever I plug extension cord into the 178. So, is that the 3.5 amp draw that is doing that ?? I've tried switching off the converter circuit, thinking that was cause, but no luck. My batteries don't last long either when boon-docking.
