  New Posts New Posts RSS Feed: Low water pressure/flow in shower
Rdenniso View Drop Down
Post Options Post Options   Quote Rdenniso Quote  Post ReplyReply Direct Link To This Post Topic: Low water pressure/flow in shower
    Posted: 23 Oct 2023 at 12:47pm
Thanks for the reply! I'll give it a try.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2023 at 12:05am
Yes. Using the stock shower head is not ideal. I use an Oxygenics shower head. That is much better.
Post Options Post Options   Quote Rdenniso Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2023 at 10:12pm
In our 2022 RP202, there is low water flow and pressure in the shower. I have a adjustable pressure regulator and set it at 45psi. When using the shower with city water connection, water flow pressure in shower is very poor. Using water pump helps, but flow/pressure is still very low. Is tis a common issue? 🤔
