slide out question |
Post Reply | Page 123> |
zzimmer3
Groupie Joined: 16 Jul 2023 Location: IL Online Status: Offline Posts: 42 |
Post Options
Quote Reply
Topic: slide out question Posted: 08 Aug 2023 at 7:20am |
I am new to r pods and having a slide. I notice when I bring the slide in or out it tips slightly, then straightens itself up when it lands all the way in or out. is this normal? or is there something that has worn that I should repair before it gets worse? thank you.
Post Options Quote Reply Posted: 08 Aug 2023 at 8:27am |
What system is your slide-out using? If it is the Schwintek, it will have tracks on the sides at the top and bottom of the slide-out box. Those should keep the slide-out moving pretty much evenly. If it is the one that is underneath, I don't know as I do not have experience with that system. I think as long as it isn't binding, but moving smoothly, the little bit of tilt should not be an issue as long as when it lands in or out it is straight.
zzimmer3
Post Options Quote Reply Posted: 08 Aug 2023 at 1:56pm |
i didn't even know there were different types of slides. lol. I'll have to look at it. my trailer is a 2015 176T model. it functions fine, i do believe. I just don't have any experience with them at all. this is my 4th camper, but first slide, so i'm a bit nervous, or cautious.
Thank you. |
hank*pod
Groupie Joined: 06 Oct 2022 Location: PA Online Status: Offline Posts: 61 |
Post Options Quote Reply Posted: 09 Aug 2023 at 11:12am |
I'm almost certain that a 2015 R-Pod would have a Schwintek slide. Does it have the aluminum strips at the top and bottom of the slide ends (that the gears on the drive motors engage with)? That's a Schwintek slide as StephenH indicates.
zzimmer3
Post Options Quote Reply Posted: 09 Aug 2023 at 11:35am |
i will look tonight. i've been so busy i haven't even got to clean or tinker around to much with it. thank you for the info.
pedwards2932
Senior Member Joined: 21 Sep 2020 Online Status: Offline Posts: 337 |
Post Options Quote Reply Posted: 09 Aug 2023 at 2:36pm |
Mine was doing that and it because of a restriction behind the kitchen cabinets. If there is anything restricting it will slow down one side.....I would look behind the pull out as it is going in.
zzimmer3
Post Options Quote Reply Posted: 15 Aug 2023 at 10:01am |
its a track on the bottom of the slide, there are no gears or tracks on the side of the slide out.
Senior Member Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3221 |
Post Options Quote Reply Posted: 16 Aug 2023 at 5:22pm |
I do not know the manufacture of the unit you have but it is the same as what I have on a 2011 177. Mine does not act as how you describe yours however check the following: look carefully at the under side of your slide and note if it is all in pristine (shiny black) condition or does it appear as though something is skidding, causing a worn pattern on the black surface. If so, get a can of penetrant and spray the 3 roller ends (they are about 2-2.5" long) located just inside the camper wall, get underneath the slide and carefully pull the rubber gasket down and you will see them (using a flashlight will make the job easier). After spraying all 3 rollers move your slide in and out a couple times and see if this doesn't correct your issue.
zzimmer3
Post Options Quote Reply Posted: 17 Aug 2023 at 9:29am |
This weekend i'm hoping to get a good look at it. i haven't gotten to do anything with it yet. its killing me just seeing it sit there, lol.
zzimmer3
Post Options Quote Reply Posted: 17 Aug 2023 at 7:53pm |
So I took a quick look at the underside of the slide. One side is black and shiny, the other side is actually cut into the wood some. It's beyond just lubing up. It's not gashed really bad, but does not look good. I'd like to get a better look soon. As soon as I climbed inside work called so I had to abandon the investigation.
