Where to get replacement door for Model 179 R-Pod? |
Post Reply | Page <12 |
poohbill
Groupie Joined: 22 Aug 2019 Location: Idaho Online Status: Offline Posts: 87 |
Topic: Where to get replacement door for Model 179 R-Pod? Posted: 21 Jul 2023 at 7:39pm |
Whew! Your electric is a monster compared to the little 80 Zamp panel we have. We have always gotten all we needed out of the 20lb bottle of propane and use very little juice camping.
I have no idea what my dimensions are, but feel free to email Eric Gibson at egibson@thesmithgroup.com and use my name.
2016 179 Gastropod
2017 Ridgeline |
Danno
Newbie Joined: 04 Oct 2014 Location: United States Online Status: Offline Posts: 11 |
Post Options Quote Reply Posted: 21 Jul 2023 at 6:45pm |
Hi, thank you for taking the time to reply and tell me about your experience. I'm wondering if the dimensions I listed match your door because I can't find anything on the web that does. Of course, Forest River is 100% unresponsive. I talked to RV Parts USA and they can only find the same 26" and even wider doors that I did. I've emailed Lippert but haven't heard back yet.
Sorry to hear about your fridge troubles. But if it will still run on either 12VDC or 115VAC, what about using solar? I run mine on 12VDC, using a 250W solar panel I mounted on the roof plus another 250W panel I mounted on the roof of my truck's camper shell. I got rid of the lead-acid batteries and mounted a 12V, 170AH lithium iron sulfate battery under the bed along with a solar charge controller and a 3,000W inverter. The battery / inverter will start and run the air conditioner and run the microwave and will run the fridge too but it's more efficient just to run the fridge on 12V instead of going through the conversion to 120VAC. Normally, I use a portable swamp cooler that takes a lot less power than the compressor air conditioner. I live in the SW now where that works great because of the dry air. Anyway, if you have a contact name and number for your dealer, regardless of where they're located, I'd like to talk to them since it sounds like they must know what the part number of the door is. There's absolutely nothing stamped anywhere on my door that I can find. Please let me know if those dimensions look correct and match your door too. Thank you!
Dan
poohbill
Post Options Quote Reply Posted: 21 Jul 2023 at 5:50pm |
Hi Dan. Although my Bigger Hammer and an oak ram was able to straighten things enough to limp through the season, we have a new door on order from Lippert, through a local Forest River dealer, for the same reason as you. We are having Lippert install a portal window and the door will arrive white in two months. The shop here will paint it in the basic green theme of the '17 models, though we haven't decided yet whether to add decals ourselves afterwards. $$$
My fridge refuses to ignite the propane now, so its useless to us for boondocking. We just came off a weeklong river trip with one cooler and fifteen pounds of dry ice, so will use that until the fridge is examined. Our model Dometic has a poor reputation and isn't easy to fix or replace. A friend just traded his 172 in on a Micro Winnie, but we just don't use it that much.
2016 179 Gastropod
2017 Ridgeline |
Danno
Post Options Quote Reply Posted: 21 Jul 2023 at 1:28pm |
I have a 2017 R-Pod, Model 179 with the wonderful Lippert hinges that bind and twist the door frame. I didn't know they did that until it just happened to mine. I now need a brand new door as the old one has come apart on the hinged side. Frame is twisted and foam core is out so far, there's a 1/8" gap between foam and frame now and door won't shut because it hits the striker plate. But I can't find any replacement doors with these measurements (measured where door wasn't warped or deformed):
Inside: 70-3/8" x 23-7/16" Outside: 72-3/8" x 24-1/2" Any help would be greatly appreciated! Dan
Dan
