Dometic Tri-mode Fridge (gas) Fault |
Post Reply | Page <12 |
poohbill
Groupie Joined: 22 Aug 2019 Location: Idaho Online Status: Offline Posts: 87 |
Post Options
Quote Reply
Topic: Dometic Tri-mode Fridge (gas) Fault Posted: 05 Jul 2023 at 8:24pm |
May I pick your brain further? If I don't like what I hear from the shop and replacement is on the table, have you found a good candidate? My neighbor just outfitted a boondocking cargo trailer and is experience with gas and 12v electrical. He is willing to help.
2016 179 Gastropod
2017 Ridgeline |
RP177
Newbie Joined: 06 Jun 2023 Online Status: Offline Posts: 3 |
Post Options Quote Reply Posted: 05 Jul 2023 at 8:47pm |
I've only heard people suggest replacement 2 way fridges and I'm not aware of a great 3 way option that is the same size. That's why I've worked so hard to investigate the Dometic RM-8501. Sorry
gpokluda
Senior Member Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 278 |
Post Options Quote Reply Posted: 06 Jul 2023 at 9:00am |
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Triumph T120 |
poohbill
Post Options Quote Reply Posted: 30 Jul 2023 at 12:58pm |
Update. We tried an old technique, not as old as the Bigger Hammer but as old as electrical switching - push all the buttons; in this case it was the Fault, which I thought was simply a light. It (switch)ed off and the propane indicator stayed on.
I AM embarrassed.
2016 179 Gastropod
2017 Ridgeline |
Post Options Quote Reply Posted: 30 Jul 2023 at 6:28pm |
Don't be embarrassed. At least it turned out to just need a reset. Mine totally died which is why I replaced it with a 2-way. I never was happy with the way if cooled (often, failed to cool adequately) in hot weather anyway.
Post Options Quote Reply Posted: 30 Jul 2023 at 7:06pm |
Well that is great news! ALL of us on this forum are in the 'learning mode' and hopefully we don't make the same error twice. My 10 year old RM 8501 died due to an ammonia leak and it was unfixable as far as I knew at the time. So it was replaced by another RM 8501 in August 2020 at a price of $ 1150 delivered direct to me from FR. Many complaints have been made concerning this fridge, I guess we have been more than fortunate. A few mods have been made to the point that with it running on 4 bars the fridge temp remains at 36-37 when outside ambient temps run 85 - 90. Back of fridge has to be facing N. or E. and I also have 3 muffin fans on the rear side to keep the air moving over the cooling fins. A baffle (using 1/8" luan) was made and has 2 muffin fans just below the upper cooling fin. The lower fan runs just below the lower cooling fin. Also the bi-metal switch was moved to within 2" of the chimney so that the fans run sooner and longer than when the switch was left in its original position which was about 6" away, in essence the fans never run when the switch is that far away with a result of having a fridge that doesn't cool worth beans, even in cooler weather.
