Battery Power |
kellogg ![]() Newbie ![]() Joined: 20 May 2023 Location: idaho Online Status: Offline Posts: 2 |
![]() ![]() ![]() ![]() Posted: 31 May 2023 at 5:25pm |
I have an RP 175 2010 and have been having issues with my outlets when hooked up to battery power. I cannot get the GFI to reset or even test when on battery power (battery health is good, batteries connected properly). I have also had some instances where my battery has been drained very quickly (less than a day) while dry camping and I only use lights (one light on the wheel well is working but dim), slide, propane fridge, and the water pump.
The outlets will work and GFI can be tested and reset when I'm on shore power. Fuses and breaker panel seem to be in working order. I have hooked the trailer up to the batteries and ran the fridge over night to make sure it wasn't my fridge drawing on the batteries and depleting them and I dont think I have a parasitic issue. Sorry for my lack of knowledge in this area but I'm looking for a suggestion on what to do next. Anyone out there have any suggestions? |
seafans ![]() Senior Member ![]() Joined: 24 Nov 2017 Online Status: Offline Posts: 164 |
Please understand the outlets or 110VAC (shore power) only. While dry camping use the refer on propane only. It should auto switch to propane? Someone on the owners form has a very nice check list on what operates what and when it's used on battery or shore power. I'll look for it.
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2709 |
+1
All the 110AC outlets require (1) Shore power, or (2) Installation of an inverter (which converts 12VDC to 110AC). Inverters are not common unless you have a relatively late model Rpod.
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3346 |
+1 on GG post. Pick up a multi-tester or voltmeter so you know what S.O.C. the battery has as the indicator is unreliable at best. For maximum battery life don't take your 12v battery below 12.2 v before recharging. Currently I have two 12v batteries that run independent of each other, usually boondock so they get used a lot. I expect to get 6 days total out of both batteries when night temps are in the 40's and the furnace gets used a lot. Also run the HW and stove during this time as well. In the summer when no furnace is used, they will last significantly longer. I do not utilize either solar or use of a generator. Batteries used: 12 year old Interstate group size 24 deep cycle and a 2.5 year old Trojan T-1275 that gives 160AH.
Colt ![]() Senior Member ![]() ![]() Joined: 16 Nov 2019 Online Status: Offline Posts: 383 |
That was a disappointment to me as well. I had hoped to have at least one plug powered on the battery. In a 180, the plug under the dinette could be easily repowered with an inverter under the seat, behind the power panel. It would, of course be very limited in the power available. A 300 watt inverter could pull the battery down to 50% in 1.5 hours. Attached is a handy SOC vs Voltage chart for flooded cells. ![]() |
John
'16 R-Pod 180 |
Good info John. I am amazed when looking at my oldest battery, a 12 year old Interstate 12v deep cycle that was trickle charged November 1, 2022 and read 12.85 volts. It then sat directly on a concrete floor in an unheated garage in northern Michigan (checked monthly) and was never given another charge until I took it out of the garage and re-installed it in a 177 on May 2nd of this year. At that time it read 12.54 volts, not too bad for a battery of that age losing only 0.31 volts over 6 months.
I've noticed your battery messages. Amazing. The cold storage annually must be good for it. Plus, immaculate care.
John
'16 R-Pod 180 |
That make sense! Thanks so much.
gpokluda ![]() Senior Member ![]() ![]() Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 399 |
We voted to put Jato's 12 year old battery in a museum, but instead they are going to send it into space to power the International Space Station for the next 20 years.
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Kawasaki KLR650 |
[/QUOTE]
We voted to put Jato's 12 year old battery in a museum, but instead they are going to send it into space to power the International Space Station for the next 20 years. ![]() [/QUOTE] Thanks, that gave me a good ![]() As far as the 12 year old Interstate that may 'end up in a museum' (purchased 04/2011) maintenance is key, never been taken below 12.2 volts before recharging and it has been used A LOT. The sister battery to it (same make, size) died 2.5 years earlier and I figure it was because when I first purchased this 177, thought it was a 'cool' idea that the Dometic fridge could run on 12v power. Found out that it did, for about 4-5 hours and then the fridge would begin to beep. Took it in the above auto parts store, they told me to trickle charge it for at least a day, which I did. I was a slow learner and tried the same scenario a week later and would you believe, got the same result! Fortunately my brother was present and brought out the voltmeter and said, "Don't do that again, that will destroy your battery - battery read 8.1 volts after powering the fridge for just around 5 hours. So after taking it down too low twice, am quite sure its life was terminally shortened by my stupidity.
