Issues with RV Lock and black glass door |
mjlrpod ![]() Senior Member ![]() ![]() Joined: 27 Sep 2016 Location: Massachusetts Online Status: Offline Posts: 1221 |
![]() ![]() ![]() ![]() Posted: 30 Apr 2023 at 8:20am |
I installed an RV lock keyless entry in my glass door 2 weeks ago. So far it's been very cool out, so no trouble. BUT when I installed it, I did have a bit of a hard time with the fit, and the slide bolt rubbing on the slide opening. Mine wouldn't open right off the bat, it was rubbing on the opening. I actually had to take my dremel and lightly grind away just a little bit of the slide bolt opening. I will wait until it warms up and see if mine develops the same problem. I'm pretty sure if you do what I did, you will no longer have trouble. I will let you know if I do have trouble.
2017.5 Rp-172
seafans ![]() Senior Member ![]() Joined: 24 Nov 2017 Online Status: Offline Posts: 163 |
I have the same issue whit my door also. Not to the extent that you seem to. The glass door must swell or twist in the frame when heated in the sun. Tempered glass acts strange when heated up.
KirstenHite ![]() Newbie ![]() Joined: 26 Apr 2023 Location: FL Online Status: Offline Posts: 1 |
Anyone with the glass door also have an RV Lock installed? If so, do you have issues with it not opening after the door has been in the sun? Our 202 is parked in a storage lot in the full sun ![]() RV Lock sent me new "brains" for the unit, but that still didn't help. I also put Energizer Lithium batteries in the lock, hoping that would help, but I still get locked out if the door is in the full sun. All other times it works perfectly. Painted the bolt with whiteout to see if I would notice any scuffing or scraping, but the whiteout is still in tact, so I don't think it's rubbing.
