2kw remote electric start generator |
Post Reply | Page 12> |
Topic: 2kw remote electric start generator Posted: 20 Jan 2023 at 3:30am |
I wouldn't recommend starting up any generator into a significant load. It's not unsafe, just hard on the generator to load it before the oil gets a chance to warm up and lubricate everything properly. Same reason why its a bad idea to do full throttle acceleration in your car before you get it up to operating temp. Better to check that your major 120Vac loads (microwave and air conditioner) are off first, then hit the remote start. Then give the genny a couple of minutes to warm up before loading it up. Running the converter during warmup is fine, that's only going to be a few hundred watts
Post Options Quote Reply Posted: 19 Jan 2023 at 3:53pm |
If you had a way to tilt the tailgate and hold it so it does not hit the power jack, you could probably run the generator from the truck bed. It would just deflect the exhaust upward. You might need to add some form of heat insulation to the tailgate though.
gpokluda
Senior Member Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 280 |
Post Options Quote Reply Posted: 19 Jan 2023 at 8:45am |
Same here. We almost never lifted our generator out of the truck bed, just kept it oriented so it would exhaust at the tailgate. The remote start is nice, but you would still have to go outside to plug in once the generator is up to power which brings up a question. Let's say you had an autoformer like a Hughes Watchdog plugged into the generator and of course your RV power cable plugged into the Watchdog. Would it be safe to remote start the generator with everything connected?
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Triumph T120 |
David and Danette
podders Helping podders - pHp Joined: 24 Nov 2009 Online Status: Offline Posts: 1215 |
Post Options Quote Reply Posted: 18 Jan 2023 at 4:11pm |
We kept the Champion 3100 in the truck and too rolled it out on the tail gate to operate it that worked well when the truck was unhitched from our camper. But we couldn't use the generator unless we were unhitched from the truck which wasn't practical in a rest area. We have a fiberglass cap on our truck which encloses the back of the truck so we needed to let down the tailgate but that wasn't possible because the tailgate would hit the electric tongue jack. So we decided to buy the Westinghouse not only can I lift it out of the truck being half the weight but it uses a lot less gasoline and now we are able to operate the generator in a rest area easily. The Champion 3100 was more power than we needed so it was overpowered for our camper most of the time. But I do miss the remote start and having the electric start feature. When we bought the Champion 3100 we thought it would be useful for the camper and when our power went off for our house which happened fairly often. But our electric company improved the power grid in our area and the power rarely goes off now.
Post Options Quote Reply Posted: 18 Jan 2023 at 9:02am |
I do that. I have it sitting where the exhaust is toward the tailgate. I lower the tailgate when I run it and make sure there is space around it, more at the front where air is pulled in, to make sure it stays properly cooled. Since mine is dual fuel, I only have run it using propane. I get a little less power, but it saves having to worry about carrying gasoline and it spilling.
As long as you have the truck so that exhaust would not be going into the RPod, you should be fine.
ZuBrew
podders Helping podders - pHp Joined: 11 Oct 2017 Location: Macedon, NY Online Status: Offline Posts: 113 |
Post Options Quote Reply Posted: 18 Jan 2023 at 8:54am |
Can you leave the generator in the back of a pickup and run it in the open truck bed? I have heard of anyone doing that and wasn't sure if it was safe or not.
I have a Champion 4250/3500W open frame inverter I picked up last summer on super special for $500. I have to find some wheels for it. I had planned to use a ramp to roll it in and out of the truck. It's 75 lbs so my wife and I can hoist it into the truck if needed.
2017 Chevy Silverado 1500 4X4
2018 R-Pod 189 2013 Yamaha FJR 1300A |
David and Danette
Post Options Quote Reply Posted: 18 Jan 2023 at 5:13am |
We have a Champion 3100 inverter generator remote start for some reason I think it has been discontinued perhaps just for a newer designed model. It is heavy at 96 pounds but having the remote feature has been convenient I just need to remember to turn off the battery switch when not in use or the battery will go dead. It has a swing up handle and wheels for transporting but is too heavy for me to lift into our truck for camping so I use ramps to roll it up into the truck. This last camping trip I decided to buy a lighter 47 pound more fuel efficient generator a Westinghouse 2500 generator. I am able to lift it in and out of the truck and it operates everything in our camper with a 2200 watt continuous power. I noticed at the campgrounds we camped at it was a popular generator the Westinghouse and the Honda were the most popular. We may sell the Champion generator now since buying the Westinghouse not much need for two generators.
Post Options Quote Reply Posted: 17 Jan 2023 at 2:01pm |
Just note that it's only rated at 1800 continuous watts. Ryobi isn't being conservative either. I saw a video where the guy loaded it to just over 1800 and it cut out after a few seconds. 1800 will run a 13.5k btu a/c though, at least at lower altitudes, but you'll probably need an easy start on the a/c.
gpokluda
Post Options Quote Reply Posted: 17 Jan 2023 at 9:58am |
At 57lbs it is manageable to be lifting out of a truck bed as well. I was looking for a 2300 to replace my two Champion 2K Cube style generators. Thanks for posting.
Gpokluda
Post Options Quote Reply Posted: 17 Jan 2023 at 4:41am |
Looks like besides starting and stopping the BT app tells you how much fuel you have left and how much longer the gen will run based on current load. Pretty nice. I might eventually get one if I can figure out how to use my existing Onan generator fuel line to safely feed it from the main fuel tank. There is a fuel pump on that line already so maybe I could add a concealed switch and use it as a transfer pump to the Ryobi?
