Roof to Side Rubber Seal Cracking/Peeling |
Post Reply | Page <12 |
Topic: Roof to Side Rubber Seal Cracking/Peeling Posted: 24 Oct 2022 at 10:35am |
I re-read the original post and your follow-up. Are you talking about the vinyl trim, the roof material, or the rubber bulb and flap seals that go around the slide-out? It helps to know the correct problem. Posting a picture of it would be helpful.
Post Options Quote Reply Posted: 22 Oct 2022 at 7:40pm |
I replaced the white vinyl trim insert on my 177 after it was 10 years old as it was beginning to crack. Ended up purchasing a 100' roll of premium 1 inch white vinyl trim insert on eBay (which in 2020 had the best price by far) and 200 stainless steel 1" long #10 screws to replace the rusted steel screws installed by FR. Also dipped each screw in Dicor before inserting. Doing the trim alone I can't imagine would take more than 2 to 3 hours tops if that is all you are doing by yourself. To do the almost 200 s.s. screw change outs and change the vinyl trim I think I had about 9 hours into the entire job. The only nasty part was drilling a bunch of new holes underneath as nearly all the steel screws had rusted away. Note: if you plan on doing that purchase a carbide tipped drill bit, a normal bit won't work, at least it didn't on my 2011 model.
Canucktraveller
Newbie Joined: 26 Jun 2020 Location: BC Canaa Online Status: Offline Posts: 4 |
Post Options Quote Reply Posted: 22 Oct 2022 at 3:18pm |
Same here on my RPod 178 (2019). My RV service center calls them "long leg moldings". Both are cracked and compromised in several places. RV service is quoting me $2800 in labor (almost 18 hours) to replace them. Seems ridiculous, especially for a trailer that's only three years old. The parts are apparently $150 CAD. Currently working on getting Forest River to cover the cost. Not happy
Happy Trails
Post Options Quote Reply Posted: 08 Oct 2022 at 5:30pm |
I think you are describing this:
This is a much heavier duty insert than what the factory uses. It has held up very well for me. I ordered it in 2018 when the thin stuff cracked for me also.
Dadboni
Newbie Joined: 06 Sep 2020 Location: NC Online Status: Offline Posts: 2 |
Post Options Quote Reply Posted: 08 Oct 2022 at 3:38pm |
RPod-179: the rubber seal between the roof and side is cracking and peeling. Is FR the only place where I can order this or are there other options? BTW: what is it called?
