RP 179 2018 |
HillbillyMedic
Newbie Joined: 15 Jan 2021 Location: WV-FL Online Status: Offline Posts: 11 |
Topic: RP 179 2018 Posted: 24 Jul 2022 at 2:30pm |
MY refrigerator doesn't work. When on 120V the plug icon, the level lights and the red light all just flash. On battery it doesn't flash, but it doesn't work either.
All fuses and breakers are ok.
Be careful.
RoverPod
Senior Member Joined: 07 Mar 2020 Location: Virginia Online Status: Offline Posts: 118 |
Post Options Quote Reply Posted: 24 Jul 2022 at 3:34pm |
What's your battery level?
2017 F150 XLT SuperCab
2020 rPod 180 |
HillbillyMedic
Post Options Quote Reply Posted: 24 Jul 2022 at 3:47pm |
Won't work on 120V. Battery should be fine. Been on shore line past two weeks.
Be careful.
Post Options Quote Reply Posted: 24 Jul 2022 at 4:07pm |
Battery "should be fine" does not answer the question. You need to verify the battery level.
Does it work on propane? Have you checked your ground fault interrupter outlet? The breaker might not be tripped, but if the GFI outlet is tripped, it would keep the refrigerator from getting 120V power.
HillbillyMedic
Post Options Quote Reply Posted: 24 Jul 2022 at 5:54pm |
Well, the battery powers everything when the shoreline is disconnected and it doesn't work on 110 with all the receptacles working. Not interested in running it on propane.
Be careful.
Post Options Quote Reply Posted: 24 Jul 2022 at 7:15pm |
Have you verified that the 110V receptacles are all operating (plugging something like a light into them or using a multimeter to check them)? As I said, if the GCFI is tripped, the refrigerator will not get 110V power, even if the breaker in the panel is not tripped.
Post Options Quote Reply Posted: 27 Jul 2022 at 9:06pm |
+1 To check that outlet, (the one the fridge plugs into) plug in a drill or lamp and see if it will operate.
