Electric brake wire connector type? |
Post Reply | Page 12> |
poohbill
Groupie Joined: 22 Aug 2019 Location: Idaho Online Status: Offline Posts: 87 |
Topic: Electric brake wire connector type? Posted: 09 Jul 2022 at 11:23am |
My fix was with XHF connectors. We'll see how well they hold up. Gastropod came off the lot with the wires on both sides hanging low, begging for a catch-n-tear. I raised them and was good for years. I wonder though if Forest River is giving this too much length to begin with.
2016 179 Gastropod
2017 Ridgeline |
Post Options Quote Reply Posted: 09 Jul 2022 at 11:04am |
Good to know that there are folks doing a lot of this kind of work that like them.
I'm a bit surprised the solder will melt before the insulation burns when using a heat gun, especially on larger gauge wires. Be on the lookout for cold solder joints. But back to the original question. Just about anything is going to be better than the OEM insulation displacement connectors which rely on mechanically pinching tiny sections of wire between two knife edges which first have to cut through the insulation. |
Post Options Quote Reply Posted: 09 Jul 2022 at 10:05am |
Aha, my smart mechanic has been using those connectors at the golf course for probably 10 years, can't beat them! They work very well in golf course applications where equipment is put through the ringer when it comes to unfavorable conditions for electrical connections. You will love them. Actually, the Toro company has been using them on some of their commercial golf equipment for many years.
Post Options Quote Reply Posted: 09 Jul 2022 at 9:47am |
Great! Let us know how they work out
Post Options Quote Reply Posted: 09 Jul 2022 at 8:11am |
Those connectors look pretty cool. I think I'll order a box.
Post Options Quote Reply Posted: 09 Jul 2022 at 7:47am |
LA, I've always done splices old school (solder then seal) like you but Ive been meaning to try these
Butt splices |
Post Options Quote Reply Posted: 09 Jul 2022 at 6:39am |
Oh, dang! I have to agree with OG. I had the same issue with the left side brake wire and had to splice in new wire to reconnect the brakes. The first time I fixed it, I used the displacement connectors and it came apart again and I had to do a temporary fix along I-80 in Utah. When we got to our destination, I fixed it again, hopefully permanently, with solder and compression butt splices and now have a solid repair. I also made sure that the wires were well protected and had plenty of length to be able to accommodate the movement of the axle. I even covered them with plastic wire loom to hopefully protect them from minor impacts with junk on the road. I used heat shrink sheathing and heat shrink butt splices to seal them from moisture, but I like the idea of the solder ring/heat shrink connectors. OG, where are did you find them?
Post Options Quote Reply Posted: 09 Jul 2022 at 3:04am |
Don't use those crummy insulation displacement connectors, they are notorious for losing connection. FR just uses them because they're cheap and quick. Many reports of those failing.
Use good quality butt splices or soldered connections, with self sealing heat shrink tubing, you'll be much happier in the long run. There are also now butt splice kits available with a built in solder ring and heat shrink that solder and shrink in one step using a heat gun. |
poohbill
Post Options Quote Reply Posted: 08 Jul 2022 at 6:54pm |
Thanks.
RoverPod
Senior Member Joined: 07 Mar 2020 Location: Virginia Online Status: Offline Posts: 118 |
Post Options Quote Reply Posted: 08 Jul 2022 at 6:12pm |
I have no idea what all those "nopes" and "you know what I mean" mean, but if you need a new connector for your trailer brake wires, this is what you need. https://www.trailerpartsdepot.com/p-7235-sealed-electric-wire-connectors-for-brake-applications-3m-brand-5-pack.aspx
2017 F150 XLT SuperCab
2020 rPod 180 |
