Gravel road rated |
Post Reply | Page 12> |
Topic: Gravel road rated Posted: 05 Jul 2022 at 5:10pm |
It would be very difficult to get recourse with a trailer manufacturer for stating too low a tongue weight.
The listed tongue weight is typically an unloaded trailer figure. That is because the DOT sets the gross trailer weight rating to be equal to the axle rating plus the lowest listed tongue weight. If the manufacturer were to state a higher tongue weight it would have to reduce the axle rating to avoid having tóo high a GTW. In practice what that means is that while the manufacturer is responsible for stating an appropriate axle and GTW the user is responsible for keeping the tongue weight in range. After all the manufacturer can't control how he or she loads the trailer. As for whether it's ok to load right up to the manufacturers limits, it's certainly legal to do so. But most folks with experience towing wouldn't do it, at least not for more than a short trip in good conditions. There is no reserve capacity left to maintain control for the weather, traffic or the other fun on the road surprises we have all experienced. |
Post Options Quote Reply Posted: 04 Jul 2022 at 9:26am |
I don't think anyone disagrees that one should not tow beyond the capacity of the TV, or even right at its limits. Weight is a variable issue, depending on the loading of the TV and trailer. As long as people keep within the limits of towing capacity, tongue limits, and CGVWR, things should be alright, assuming prudent driving while towing. Manufactures who mislead on weight issues expose themselves to liability for misrepresentation and that can be very costly if something awful happens. But, as in all things in life, we can count on manufacturers and sellers to push the limits, and sometimes beyond.
The person towing has a responsibility to do his/her homework and properly calculate towing weights. That certainly includes getting a baseline weight by actual measurement. If it turns out that the seller or manufacturer's figures are really off, there are remedies, but they can be costly to utilize.
Post Options Quote Reply Posted: 04 Jul 2022 at 8:44am |
I too thought my 179 and Highlander (pretty much the same specs as the Ridgeline) combo were very well matched. We could carry everything I needed to and nothing else.
Here is a good towing calculator. All the specs for the TVs are quite readily available, including for the Ridgeline. The main issue is to know your actual TV and trailer weights. No good way to really know that without going to a public scale, so it's best to do that with the TV, people and gear and just use the trailer max weight if you don't own the trailer yet. I've yet to see an actual trailer tongue weight that is in line with published numbers. That is especially true when boondocking and carrying water, propane batteries, etc. If your tongue weight is really the listed 400lbs on a 4400 lb trailer then it's too low at only 9%. You need a high tongue weight to counteract sway tendency, so the heavier the trailer the higher the tongue weight needs to be. I would just assume 13-14% of the max trailer weight for a trailer I couldn't weigh. This allows for weight to move further aft depending on how you load and still stay above the 10% number considered to be the bare minimum. My 179 ranged for 11 to 14 percent tongue weight depending on which tank(s) had water in them. towing calculator |
David and Danette
podders Helping podders - pHp Joined: 24 Nov 2009 Online Status: Offline Posts: 1215 |
Post Options Quote Reply Posted: 04 Jul 2022 at 8:07am |
Nash RV and Outdoor RV build good off road RV's but the smallest would be heavier than a r-pod. They have shock absorbers on their axles to help soften the ride on bumpy roads and they have a stronger frame they are built for off road. The lightest I think is about 4,000 LBs. A few years back you could find used ones for a lot less money than they are now but that is true with about all RV's.
Post Options Quote Reply Posted: 04 Jul 2022 at 6:37am |
It's really up to poohbill to determine what fits his needs best. I am sure he is perfectly capable of calculating his weight situation, especially if he uses one of the trailer weight apps. The problem is getting the data from the manufacturers to make the calculation. Some are a little vague about the CVGWR.
As for our Sonoma, the tongue weight is within the capacity of the R.L., with 40 pounds to spare, at least according to the manufacturer's trailer specs. Glad to see we agree on rough and steep roads.
Post Options Quote Reply Posted: 04 Jul 2022 at 5:49am |
10% margin on towing capacity but not on GCWR. With a realistic 800 lbs of people, supplies, gear and a wdh in the Rigdeline, it is at 97% of gross combined vehicle rating. Still legal but marginal. You have to remember that tow ratings do not assume a fully loaded tow vehicle. You'd have to check the tongue weight and rear axle load as well, tongue weight is very likely over. And a wdh does not give give you any weight increases. I'm sure your Sonoma is a great trailer when towed behind an F150 which is significantly more capable than a Ridgeline or the Highlander I have. But it's too much trailer for that TV, especially considering the rough/steep road use case. |
Post Options Quote Reply Posted: 04 Jul 2022 at 5:33am |
Ufff, the forest burning. That's one of the reasons we moved from Dayton, NV. We couldn't go camping for most of last summer due to fires and closed campgrounds and were trapped in smoke even when we were home. I hope the fires are fewer and less destructive this year. It is truly heartbreaking.
The Catalina Expedition looks like a very nice trailer. Its GVWR appears to be right at the weight limit of the Ridge Line, so there isn't much of a margin of error. It's about the same length as our trailer and about 4" wider. The layout is practically identical to the bunkhouse version of the Sonoma, but it looks, from the spec list, to have some upgrades. I can't believe how much the prices of trailers have gone since we bought our Pod replacement, especially the single axle small trailers.
poohbill
Groupie Joined: 22 Aug 2019 Location: Idaho Online Status: Offline Posts: 87 |
Post Options Quote Reply Posted: 03 Jul 2022 at 7:45pm |
We bought the 20’ Gastropod 179 in 2016, then the Ridgeline the following year. They are a beautiful pair and match our needs perfectly. My garage limits my truck size and my truck size in turn limits the trailer. We have several favorite lakes in Montana and Wyoming we have traveled up to with the pair, learning not to stow heavy items in the trailer and how to make minor cabinet repairs when we did. After the first year of destruction, I slowed down significantly and left much earlier in the day. What I am seeing now isn't too bad all in all - it is a big box swaying much more than a structure of that volume should without internal bracing.
So, I'm looking toward the day when still constrained by my older, smaller, garage bays, the Gastropod serves up its last meal. It is our first trailer and I feel comfortable now towing something that size. Honestly, it tows so easy with my 2017 RTL that Coachman's Catalina Expedition (2’ longer and a half-ton heavier) seems doable. We really like those high mountain lakes for the two months every year they are reachable. Unless the Forest is burning.
Post Options Quote Reply Posted: 03 Jul 2022 at 6:53pm |
It all depends upon the margin over the weight of the trailer you want with your towing capacity.
The GVWR of our trailer is 4400 lbs., so it would give a tad better than a 10% margin with a 5000 lb. towing capacity. Poohbill may find it perfectly adequate, unless he is towing in very steep terrain at high altitudes with a naturally aspirated engine. We've taken it on US Forest Service roads with no issues. Again, going slow and avoiding very abrupt grade changes where the hitch could hit. If we had a set of those fancy air shocks to raise the back of the truck to get more ground clearance, hitch clearance would be no problem. The NuCamp Tab is a really nice trailer, but for some, it's a little on the cramped side. We've spent as long as 6 weeks in our Sonoma and never felt cramped. It's kind of nice to have the bed and dinette separate along with a full bath, a galley with a 3 burner stove and oven, and a 6 cu.ft. refrigerator with a big freezer. Also, we found that the insulated and enclosed floor on the chassis side has been effective in keeping things from freezing in some very cold temps, that I've posted about before. Everyone has his or her preferences, as governed by the capacity to pay for what ever one may wish to buy. We paid about half of what a NuCamp Tab 320 costs. Add another $13K and you can get a 400. Even with the smaller camp sites in older campgrounds that we've been noting in New England's limited national forests and state campgrounds, our trailer fits into the small sites just fine. We couldn't be happier with the trailer we have, but that's our personal preference. |
Post Options Quote Reply Posted: 03 Jul 2022 at 4:36pm |
But your Sonoma is not really towable by a 5000 lb rated TV like the OP has, right LA?
Possibly one of the NuCamp Tabs might work ok with care on FS roads. They are light enough for a 5000 lb TV and (I think) better constructed relative to FR products. |
