Refrigerator |
Post Options
Quote Reply
Topic: Refrigerator Posted: 31 May 2022 at 3:52am |
Often, ice buildup can happen quickly if the door isn't totally shut or if part of the sealing gasket has been compromised. Since you state this hasn't happened before possibly one of these are your issues. Open the lower vent cover on the outside (behind the Dometic fridge) to access the rear of the fridge. Along the metal propane supply tube (before the combustion area) you will find a small plastic tub with a clear plastic tube running to it. Check to see if the tub is full or if the plastic line running to it is plugged or kinked somewhere. If necessary, remove the plastic line and run some compressed air through it.
Rodg Pod
Newbie Joined: 15 Dec 2020 Location: Santa Rosa, CA Online Status: Offline Posts: 6 |
Post Options Quote Reply Posted: 31 May 2022 at 1:04am |
Just got back from 5 days out at Mackerricher SP in Fort Bragg CA. I had a lot of condensation under the entire freezer. Refrigerator blades were also soaked and the ones on the right hand side were starting to get ice build up. This much condensation hasn't happened before. Does anybody have any tips on how to prevent this, or how to access the drain tube to see if that has gotten clogged. Any advice would be greatly appreciated. Thank you
Rodger
Santa Rosa, CA 2017 179 Hood River Edition 2012 F-150 FX2 Everyday is Saturday - No more work |
