So Far No Issues |
Post Reply | Page <12 |
Senior Member Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3215 |
Topic: So Far No Issues Posted: 07 May 2022 at 9:11pm |
When set as 85 psi I have one line already open. Once water is purged out I then open a second line and then close the first and so on. In other words one line is always open at this pressure.
Dirt Sifter
Senior Member Joined: 30 Dec 2018 Location: Right side OR Online Status: Offline Posts: 170 |
Post Options Quote Reply Posted: 08 May 2022 at 8:28pm |
Wow! 85 psi!? I use 40 - 45 psi and check each valve at least twice until no moisture forms on my fingers each time. I have no need to test the suggested 40 psi water pressure limits. Have done that for years with various TT's and it's worked in NE OR winters that routinely get into minus double digits Fahrenheit. Along with pink stuff for the p-traps, toilet of course. Always learning something on this forum!
Greg n Deb 2020 195 HRE
'07 Tundra 5.7L., '17 Tacoma 3.5L. Both with tow packages 1 Puggle, 1 Chihuahua support staff |
Post Options Quote Reply Posted: 09 May 2022 at 5:28am |
Even though the incoming pressure is 85 psi, with one line always open the line pressure is going to be quite lower. How much I don't know as it has never been measured but it doesn't take long to see no mist coming out of each line. Don't even check the bowl in the inlet side of the water pump anymore as it was always dry after performing this procedure.
