  New Posts New Posts RSS Feed: Fresh water tank sanitation
Mooree View Drop Down
Post Options Post Options   Quote Mooree Quote  Post ReplyReply Direct Link To This Post Topic: Fresh water tank sanitation
    Posted: 20 Jul 2023 at 11:24pm
The amount of bleach needed to sanitize the RV tank is about one cup of bleach for every 40 gallons. A 43-ounce bottle of bleach can cost $10 or more, depending on the brand, but you can save a lot of money by using it for routine RV water tank cleanup.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 8:57am
Well, you do need to sanitize that water line also. You don't want to leave any bacteria in the supply line that could migrate back through and contaminate the rest of the water system. That is my thought. It really isn't that much bleach that is being added to the black tank in proportion. It is also of a weak concentration. Once the process is done, if you really are concerned, drain and flush the black tank and add a good biological tank treatment. If it is already empty, the bleach should dissipate quickly since the black tank is vented. You could just treat the tank and I think you will be fine. It has worked well for me since we got the RPod.
Colonel Podder View Drop Down
Post Options Post Options   Quote Colonel Podder Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 8:13am
I noticed when reading through this thread that some may be running the bleach through the toilet. I thought that you should never put bleach in the black tank?
2021 R-pod 196
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2022 at 3:13pm
The R-Pod has a 30 gallon tank. The water heater is 6 gallons. That is a total of 36 gallons. So, 3/4 cup bleach would be appropriate if one is using the formula of 1 cup per 50 gallons capacity.
Post Options Post Options   Quote Mooree Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2022 at 12:28pm
Using bleach to disinfect water tanks is not new to every RV, but how much bleach is needed to disinfect an RV water tank. We need to know the exact amount to kill pathogens and keep them at a safe level. In general, we will need one cup of bleach for every 50 gallons of water. Therefore, if your water tank has a capacity of 25 gallons, use ½ cup bleach. If your water tank can hold 12-13 gallons of water, use 1/4 cup.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2022 at 1:12pm
Bleach won't affect the anode rod. RV antifreeze would which is one reason besides not wanting to fill it up with antifreeze to bypass the water heater, pull the anode rod, and drain it while winterizing.
Linward View Drop Down
Post Options Post Options   Quote Linward Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2022 at 12:19pm
Thanks all for the info.  But now I have another thought.  Should the bleach sanitizing and odor/taste neutralizing include the hot water heater?  I am concerned that it might negatively affect the anode rod.  I guess I could remove the rod and plug the drain hole???
It's all about choices.
mjlrpod View Drop Down
Post Options Post Options   Quote mjlrpod Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2022 at 2:12pm
On a 196, the water heater is under the fridge. Behind the vacuum if you have one. Some models have an access panel on the side to get to the hot water valves. There are 2 valves.  If you want to use the hot water heater, point the handle of the valves toward the h/w tank. To bypass the tank, handles point inline with the waterlines.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2022 at 6:47pm
I am of the alternate opinion, I never sanitized my FWT, yet we used it all the time, almost never having water hookups where we camped.
We only used the FWT for showers and dishwashing. Cooking, drinking, toothbrushing water was always taken from a 2.5 gallon bottled water dispenser. I learned this from many years traveling in remote locations in underdeveloped countries.
This approach has the advantages of never having to worry about ingesting contaminated water and also allowed us to bring a few extra gallons. Since water was our limiting factor boondocking that extended our stays. And regardless of how well you sanitize your tank you can't ever be sure the water your putting in it is really safe, there could be contamination somewhere in the water system.
In any case that's what we do and why. Others do the sanitation thing and are comfortable drinking the FWT water. As you say it's all about choices
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2022 at 6:41pm
Depends on your bypass system.  Some have 2 valves others, like mine have 3.  Regardless of which system you have by turning the handles perpendicular to the pipe - that will be off or bypass.  On the 3 valves system the top and bottom valves will be turned perpendicular to flow to turn off or bypass.  The middle valve will be turned to the open or 'in line' or parallel with the pipe position - this is for winterization mode.  Do just the opposite when you wish to de-winterize.
I did not know about sanitizing the tank for the first 5 years of ownership and my wife and I use the FW tank for drinking a lot - fortunately we never got sick.  So finally on year 6 we sanitized but then had a problem with the taste of the water.  Took us a combination of 4 attempts to rid the tank of that nasty chlorine/bleach smell and taste.  Used a combination of 1 cup white vinegar, 1/2 cup baking soda and 1 cup of 100% lemon juice concentrate in 15 gallons water.  Run through all lines for a minute (skipped the toilet line) and let sit overnight.  Next day ran through all lines until we ran out of liquid - took about 20 minutes if I recall.
