Solar generators |
Post Reply | Page 123> |
Topic: Solar generators Posted: 31 Oct 2022 at 6:59pm |
Maybe I'm living in a time warp but I have never had anything stolen from a campsite. Knock on wood. I try not to leave overly tempting items out unlocked, and I may have run a cheap bike cable through the "suitcase" of my solar suitcase. It would be pathetically easy to overcome that, and I haven't always done it I know what you're saying though. TT
FJ Cruiser |
john in idaho
Post Options Quote Reply Posted: 31 Oct 2022 at 10:38am |
I hav e a suitcase solar panel either 100 or 150 - I would have to go to the barn to check. But I have not found a way to secure it from a snatch and grab thief, which sort of limits its usefulness. It will keep the batteries topped up in the winter here at home.
mjlrpod
Post Options Quote Reply Posted: 30 Oct 2022 at 5:37pm |
I have the 1000 explorer. I felt the 500 extra that the 1500 put out wasn't worth the cost. Your mileage may vary. The panels are pretty light, but so far I havent had any issue. Granted I've only charged it up a few times so far, I got it about a month ago, and camping season is close to done. I will still use it this winter I think. As a back up system at a minimum. |
gpokluda
Senior Member Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 278 |
Post Options Quote Reply Posted: 30 Oct 2022 at 5:09pm |
@mjlrpod, what size Jackery did you get. I was looking at the 1500 when I started this experiment. How are the solar panels holding up. A couple of folks that I had talked to who had Jackerys said that it doesn't take a lot of wind to start moving them around.
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Triumph T120 |
mjlrpod
Post Options Quote Reply Posted: 30 Oct 2022 at 3:27pm |
My Jackery can run my coffee maker effortlessly. I use it mostly for coffee, and T.V. at night. It works great and 200 watts of solar panel, I can top off the jackery fairly easily. I too will be hauling my Generator around for a while till I figure out exactly how to make everything work the way I want. Luckily, I already had the genny's so no biggie.
Post Options Quote Reply Posted: 24 Oct 2022 at 4:09am |
7 amps is all you should ever expect to get from a 110 watt solar module. Solar modules are tested and rated full sun conditions at room temperature. As soon as you take them outside and put them in the sun they heat up. Power output goes down about 0.5% per degree C temp rise, and under full sun the module temp will rise by around 25-30 deg C. So out of the gate you will lose around 15%, more on a hot day of course. So at a normal charge voltage of around 14 volts you might get 110x85%/14= 6.7 amps. And that's under perfect conditions, no shade of any kind, perfectly clear sky, module pointed directly at the sun.
No one should be surprised if they rarely see more that 5 or 6 amps out if a 100 watt solar module. That being said, I disagree with the suggesting that solar might not be tried and true. It is far more reliable than any other power source you could own. There's really nothing to go wrong, you just have to understand want it does and doesn't do. Set up your solar module facing south in a shade free location at a tilt angle of around your latitude minus 15 degrees pretty much anywhere in North America in the summer months and you'll get on average at least 4 hours of equivalent full sun. So that's around 25-30 amp hours per day into your battery. That's enough for most folks boondocking if they're careful in their electricity use and don't expect to run air conditioners or microwaves or coffee pots or other heavy load ac appliances. If you get a string of rainy days, you'll either need a generator or a large enough battery to get you through the cloudy period. How big? Around 4 days autonomy. So if you're using 25 amp hours a day you'll need around 100 amp hours available capacity, or around 200 amp hours rated capacity if using lead acid, maybe 120-130 ah if using lithium. You should still set up you solar though, even on a cloudy day you can get 1 or 2 sun hours, so that's 6-14 amp hours, which could up to double your boondock time. Camping under trees with no sunny spot for your module? Bring that generator or enough battery capacity to last you through your boondock period. |
LongRanger
Newbie Joined: 13 Jun 2019 Online Status: Offline Posts: 33 |
Post Options Quote Reply Posted: 23 Oct 2022 at 4:59pm |
Thanks. That answers a lot of my questions. I've been iffy on trying the solar. Think I'll stay with the tried and true for now.
gpokluda
Post Options Quote Reply Posted: 23 Oct 2022 at 4:12pm |
Hi Lone Ranger
I was just going to post some musings as we finished up a round of campground and dispersed camping in Northern New Mexico before winter arrives in the mountains. It has been about 8 months since we outfitted the 179 with an 1000W inverter, new group 24 DC batteries (2) and a GoPower 130 portable solar kit. My goal was to be able run our small coffee maker and charge phones and other devices without having to lug the generator around. So far after roughly 7K miles of traveling including a loop up around the Pacific Northwest and back, I have to say that the setup met expectations. However, unless I get more battery capacity and more solar panels, my generator will always be in the back of my truck. While I have no statistics to measure, my gut tells me that the solar setup probably provided less than 10% of the power used while the generator supplied the rest. A lot of this is due to where we camp in the summer months, forested mountains where our panels rarely had access to direct sunlight and usually only supplied 5-7amps to the cause. So, in addition to having a generator (which weights about 35lbs), I also had 30+lbs of solar panel in the truck. No matter how you look at it, the value proposition isn't there. Where the panels do come in handy is when the 179 is in storage. I no longer have to remove the batteries as I just set up the panels and have the sun keep them topped for me. We will now switch to our winter camping mode and head south to the deserts until April. With fewer trees and more access to clear sky, I hope the panels perform better but with a lower sun angle, I'm not holding my breath. All in all it was a fun experiment but I am not completely sold on solar and RVs yet. FWIW, I originally was looking at Jackery solar generators. While they may not have met my use case, we sure have seen a lot of them this summer and fall.
Gpokluda
LongRanger
Post Options Quote Reply Posted: 20 Oct 2022 at 9:02pm |
Post Options Quote Reply Posted: 13 Mar 2022 at 7:20pm |
Good. I am glad you found a workable solution. I look forward to reading how it works out during your upcoming trip.
