Rear Stabilizer Jack |
![]() ![]() ![]() ![]() Posted: 04 Oct 2021 at 10:06am |
Mine were mounted diagonally as well. Since the stabilizers are very stiff parallel to the scissors and much more flexible perpendicular to the scissors I agree that diagonal mounting ought to be better overall than if they were mounted with the scissors parallel to the frame. Best would be with two stabilizers toed in and the other two toed out, then there would be good lateral resistance in all directions.
john in idaho ![]() Senior Member ![]() ![]() Joined: 04 Nov 2014 Location: Eagle Idaho Online Status: Offline Posts: 613 |
And when you put them back on, try a Sav-a-Jack. Still have my originals after 6 years......
Colt ![]() Senior Member ![]() ![]() Joined: 16 Nov 2019 Online Status: Offline Posts: 383 |
I believe that's how my rears are mounted. |
John
'16 R-Pod 180 |
Pod People ![]() Senior Member ![]() Joined: 22 Sep 2011 Location: Chapel Hill,NC Online Status: Offline Posts: 1088 |
I would suggest that IF possible, think about orienting the base so that one bolt/screw is on the main front/back frame member and one on the side to side frame member. It seems logical that this might help side to side stability. maybe the engineers can comment?? Travel safe Vann
Ben Herman ![]() Senior Member ![]() Joined: 26 Apr 2018 Location: Gr Junction, CO Online Status: Offline Posts: 359 |
I replaced mine in the back after banging them up on a hillside. Not hard to do, used these:
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3365 |
I replaced both mine about 5 years ago due to uneven ingress and egress areas while boondocking on back roads. First thing was to add a 3.5" lift kit from FR - took just under 1 hour to change out using a pair of floor jacks and basic hand tools. To address your question. I did not tack weld the new ones back on. In fact I did have to drill a few new holes as the old ones were to wallered out to due justice with new stabilizers. I got mine off EBay , at that time they had the best price and free shipping. Look under scissor jacks or stabilizers.
I drug one of my stabilizer jacks and bent the crap out of it. It has 4 bolts and 2 tack welds. Must it be welded?
What kind is it? Where is the best place to get a replacement? |
John
'16 R-Pod 180 |
