Electric Jack failing |
Post Reply | Page 12> |
Ricktoon
Groupie Joined: 24 Sep 2020 Location: Montana Online Status: Offline Posts: 67 |
Topic: Electric Jack failing Posted: 29 Aug 2021 at 3:18pm |
I saw a recommendation for using a 5-gallon bucket to cover the top of the electric jack head. Use the chains to keep it in place while parked and you have a bucket in case you need it. |
Rick and Ellen B
2019 Chevy Colorado 2021 Rpod 196 |
poston
podders Helping podders - pHp Joined: 28 Mar 2018 Location: Nevada Online Status: Offline Posts: 195 |
Same here. I just wish I could memorize which direction is up or down. I'm at about 75% now and if I think about it before switching I get it right, but I want my fingers to know which direction to go without having to invoke my brain! |
-- Jim Virginia City, Nevada 2016 R-pod 180 2015 Nissan Xterra Pro-4X |
DaveB1701
Newbie Joined: 24 Jun 2021 Location: Green Bay, WI Online Status: Offline Posts: 36 |
Posted: 29 Aug 2021 at 11:26am |
When you do get it repaired or replaced, I recommend a waterproof cover...one of the first accessories I bought for my Escape Pod after watching some vids about failure due to water intrusion...I don't even bother to remove it during use, just had to learn where the UP/DOWN switch was as opposed to the light switch.
Also sprayed the inside of it with Ortho Home Defense (& let dry) prior to install to reduce risk of any angry 'black & yellow' flying visitors during use.
2021 R-Pod 171
2017 Chevy Colorado Z71 V6 Just me & my pooch Mr. Buster... |
Dirt Sifter
Senior Member Joined: 30 Dec 2018 Location: Right side OR Online Status: Offline Posts: 170 |
Posted: 29 Aug 2021 at 8:21am |
You might be at the retracted limit and be wedged. The first time I used an electric jack I ran it the wrong direction and started blowing fuses. After removing the rubber plug on top of the jack I used a socket to turn it in the right direction a couple turns, replaced the fuse again, then pushed the switch in the correct direction, the jack worked just fine.
Greg n Deb 2020 195 HRE
'07 Tundra 5.7L., '17 Tacoma 3.5L. Both with tow packages 1 Puggle, 1 Chihuahua support staff |
Posted: 28 Aug 2021 at 8:36am |
Somewhere on the forum is a picture of where someone modified a hand-crank jack to be used with a drill-driver. It is likely a good way to have the convenience of an electric jack at a lower price. You would need to use the advanced search and search for posts from any date to find it though.
RFrog
Newbie Joined: 10 May 2021 Location: Santee Online Status: Offline Posts: 16 |
Posted: 27 Aug 2021 at 10:00pm |
Not on my 180, unfortunately. I checked that prior to ordering. It was not an expensive item, so well worth it. I agree it is surprisingly easy to hand crank. Did not try using my impact driver in lieu of the crank because once it seized I was out. Just give me stuff that works, please.
~dani~ 2019 RP180 purchased 5/15/21; towed by 2014 Willys Jeep Wrangler Unlimited
mjlrpod
Posted: 27 Aug 2021 at 7:50am |
I thought the stabs handle would also fit the jack? Maybe not. |
2017.5 Rp-172
Colt
Posted: 26 Aug 2021 at 11:21pm |
Using the manual crank is surprisingly easy. I would not hesitate to change it for a manual, either.
John
'16 R-Pod 180 |
ERS1977
Newbie Joined: 30 Jun 2021 Location: ON Online Status: Offline Posts: 7 |
Posted: 26 Aug 2021 at 10:04pm |
Have you tried using an electric drill or manual socket wrench to raise/lower the jack? This would ensure the jack is not seized.
RFrog
Posted: 25 Aug 2021 at 12:00am |
Mine didn’t come with a crank (bought the unit previously-loved), and the first semi failure/stubborn hissy fit of the jack I ordered that key pronto. I ended up needing it, and ultimately ended up needing to replace the whole landing gear/jack. Of course the new one came with a crank and it’s different than the old one. I hope you can get yours fixed!
