Install an inverter? |
Post Reply | Page 12> |
2hotchilis
Newbie Joined: 29 Jan 2021 Location: WA Online Status: Offline Posts: 18 |
Topic: Install an inverter? Posted: 14 Aug 2021 at 1:16pm |
Well I went ahead and installed a USB 12v charger. I got power from the radio as suggested. It was easy peasy and I learned how to use a voltmeter to boot. Yeehaw!!!
Thanks for all the suggestions. |
Darla
2017 R-Pod 179 |
2hotchilis
Posted: 27 Jul 2021 at 11:58pm |
Thanks for the help. As I was pondering today about my choices for places to mount a 12v outlet and USB outlet, that is exactly what I thought of. Then my husband reminded me that we have a small charging station that has a 12v and 110 v outlets. No fuss no muss. We’ll use it for charging phones.
Darla
2017 R-Pod 179 |
Gualalapod
Newbie Joined: 12 Oct 2020 Location: California Online Status: Offline Posts: 15 |
Posted: 26 Jul 2021 at 9:16am |
There are also a few youtube videos on how to do this. Look for the easy way one. Or..you can have an electrician do it for you.
Gualalapod owner
john in idaho
Posted: 26 Jul 2021 at 9:06am |
Like wise on leaving the AC plugs and circuits alone. Remember - you are camping in a fancy tent. Take your 12 charging station to the TV - there are 12v plugs there. If you do not understand how electric things work don't try to cobble something together in the pod. The majority of RV fires are related to the 12volt system. An RV fire will consume the RV in a matter of minutes. From talking to 2 folks who survived such a fire, there was barely enough time to get out the door.
Posted: 26 Jul 2021 at 5:41am |
I would suggest leaving the existing 120vac receptacles alone.
In the 179 a simple option is to pull out the audio box so you can access the wires and the side wall, then tap the 12v supply to the audio box to supply a combination 12v power port (aka cigarette lighter port) and USB port. Install that through the wall near the TV.Then reinstall the audio box No wires will show. That way you have power to run a dual voltage TV as well as your devices. I attached a little shelf up there as well so I could put our phones on it while charging so they wouldn't be in the way. There isn't a wiring diagram for rpods, probably because there are so many variations that it would be very difficult for the factory to keep them up to date. To add to the confusion there are two wire color code standards used on 12V systems in RVs. The automotive (red +12v, black neutral) and the Electric Code (black or red +12v, white neutral). And then if you aren't the first owner who knows what the previous folks did. Not to worry. Buy a multimeter so you can confirm you have the right wires, voltage and polarity before you make your connections. |
2hotchilis
Posted: 25 Jul 2021 at 11:05pm |
Thanks everyone for your suggestions. I will be installing 12v usb ports somewhere. If you have done this please let me know how you did it.
Darla
2017 R-Pod 179 |
2hotchilis
Posted: 25 Jul 2021 at 10:59pm |
I will look 👀 into installing a 12v outlet. That would be sufficient. Is there any diagrams for doing that in an RPod?
Darla
2017 R-Pod 179 |
2hotchilis
Posted: 25 Jul 2021 at 10:55pm |
Thanks. I haven’t seen any USB plugs. I changed one of the 110 outlets to an outlet with USB.
Darla
2017 R-Pod 179 |
Posted: 25 Jul 2021 at 2:51pm |
john in idaho
Posted: 25 Jul 2021 at 2:44pm |
Remember -= propane is heavier than air and sinks to the ground. I had a burn patient one time that had an (old time) pickup camper like a lot of us used to have, and they all came with a built in oven. By the time they got the oven lit, all the propane on the floor lit off and blew the poor person out the back door. Propane leaks are very dangerous. Don't dally in getting it fixed.
