  New Posts New Posts RSS Feed: Tire replacement
Topic ClosedTire replacement
Jefferson View Drop Down
Direct Link To This Post Topic: Tire replacement
    Posted: 23 Jun 2021 at 7:25pm
Thanks all for the informative and helpful replies - staying with the 15" tires and will look into purchasing Carlisle or Goodyear in ST225/75R15 assuming you can use the same rims as discussed - the 235/75R15 and the 225/75R15 are very close in size - just wanted to confirm they were close enough : )
Best,
Jefferson
Direct Link To This Post Posted: 23 Jun 2021 at 6:48pm
+1
We are on our 3rd set of tires, first time with "D" load rating as the first 2 sets were  "C".  Went with Carlisle, excellent tire, no issues.  Make certain you pay a few extra $$ to get them speed balanced.
poston View Drop Down
Direct Link To This Post Posted: 23 Jun 2021 at 4:39pm
Originally posted by Jefferson
Do you have to replace the rims/wheels if selecting a pair of more commonly found ST225/75R15 replacement tires, Carlisle or Goodyear Endurance or similar?
You shouldn't have to replace wheels if you stay with 15" tires reasonably close to the original width, which any trailer tire will be.
Jim
Virginia City, Nevada
2016 R-pod 180
2015 Nissan Xterra Pro-4X
Pod People View Drop Down
Direct Link To This Post Posted: 23 Jun 2021 at 3:54pm
I replaced the tires(205's) on our 179 with Goodyear Endurance 215's and did not need to replace rims.  I did use improved valve stems and balanced them
they are quite superior to the originals installed by the factory.  The sidewalls are stiffer, they bounce less, do not leak air and seem to roll smoother and quieter.  I like them after 1.5-2 years
Vann
Vann & Laura 2015 RPod 179
Direct Link To This Post Posted: 23 Jun 2021 at 12:51pm
Reviewing the previous posts on replacing original tires on 2015 HRE Rpod 177 and similarly equipped pods, seems prudent to replace the original Westlake LT235/75R15 M+S now because of age, despite relatively low mileage. As others encountered, this is an odd-sized Light Truck tire with a "C" load rating. Prefer a "D" rated ST tire.
Question: Do you have to replace the rims/wheels if selecting a pair of more commonly found ST225/75R15 replacement tires, Carlisle or Goodyear Endurance or similar? Also would appreciate some tire recommendations or knowing more about what others in this situation have done.
Thanks all!
Cheers,
Jefferson
2015 HRE Rpod 177
TV: 2007 Chevy Silverado LT, 4.8L V8
