  New Posts New Posts RSS Feed: ?brake controller module
Topic Closed?brake controller module
Jefferson View Drop Down
Direct Link To This Post Topic: ?brake controller module
    Posted: 15 Jun 2021 at 1:26pm
Hi all,
Bought a 2007 Chevy Silverado LT with tow package for towing my recently purchased 2015 Rpod 177. Need help identifying this module mounted beneath the steering column? Is is a "plug and play" module for the required brake controller? Thank you so much.
Cheers,
Jefferson
Direct Link To This Post Posted: 15 Jun 2021 at 1:32pm
Direct Link To This Post Posted: 15 Jun 2021 at 1:40pm
Here's a photo of the module on my 2007 Chevy Silverado...finally uploaded : ). Thx for any help identifying it!  --Jefferson
campman View Drop Down
Direct Link To This Post Posted: 15 Jun 2021 at 2:04pm
Hello Jefferson. That port looks like your OBD2 port (On board diagnostic port). That is used for diagnosing any engine/emission/exhaust issues.
Will research further, just in case!
Andy
Andy and Laurie
'21 RP192
Red-Green
Direct Link To This Post Posted: 15 Jun 2021 at 2:07pm
Thank you Campman...that makes more sense : )
Direct Link To This Post Posted: 15 Jun 2021 at 2:12pm
You are most certainly welcome!
If you have a obd2 code reader, you can plug it in there to read any codes that have come up (when your check engine light comes on usually) and clear them...but that won't clear up any problems.
Andy
Andy and Laurie
'21 RP192
Red-Green
Direct Link To This Post Posted: 15 Jun 2021 at 2:32pm
Awesome, thank you and good to know!
GlueGuy View Drop Down
Online Status: Online
Direct Link To This Post Posted: 16 Jun 2021 at 3:37pm
+1 re: Campman. That is the OBD2 port. On our F150 there was a connector behind the dash where the TBC plugs in. I just removed the cover (had to push in a couple of tabs). The TBC plugs into that spot and it's just like OEM. I bet your Silverado is similar.
