Choosing a smaller Truck to Tow |
Post Reply | Page <123> |
campman
Senior Member Joined: 26 Mar 2021 Location: La Salle, MB Online Status: Offline Posts: 209 |
Topic: Choosing a smaller Truck to Tow Posted: 08 Apr 2021 at 4:24pm |
I would like to add a few more suggestions as I have just spoken to my wife (and listened!).
We also have a bit of a height differential, I am just under 6 ft tall and she is 5 ft tall. Some of the must haves when selecting our truck was an 8 way adjustable drivers seat (we wish ours had both front seats that were adjustable like this...but at a minimum the drivers seat to allow for the different body lengths (we actually have to have a 2x10 piece of wood on the passengers side floor so she can have her feet planted securely and comfortably). The 2nd thing that allows my wife to drive our full size truck is the adjustable pedal option...whoever climbs in can set the seat and pedals etc and off we go. |
Andy and Laurie
'16 F150 5.0 4X4 w/factory tow pkg '21 RP192 "If the women don't find you handsome...at least let them find you handy!" Red-Green |
Posted: 09 Apr 2021 at 6:38am |
5000 lbs is the minimum for a 178. If you plan on boondocking I'd suggest higher. I do and I'm right at the limits on tongue weight, water and batteries are heavy.
The only other comment I have is the 170/180 series rpods are narrow enough that they don't necessarily need extension mirrors. I don't use them, try for yourself first. The 190 series are wider and do need them. |
Posted: 09 Apr 2021 at 11:42am |
We don't have tow mirrors on our F150, and the view aft works very well with the narrowness of the RP179. Tow mirrors would probably be better, but it's actually pretty good with the standard mirrors.
Posted: 09 Apr 2021 at 2:24pm |
+1 Even though our truck is two years newer, mirrors and the like are most likely nearly identical as on yours and do not feel there is a need for additional tow mirrors. Even on the '94 F-150 the view we had from the mirrors was more than adequate.
Colt
Posted: 09 Apr 2021 at 3:47pm |
Mine was a 2007. As to wider mirrors, I'd like to have some, but I can see my wheels and some area beside/behind my 180. I've added a wireless rear view camera that I thinks is fabulous! However, I have to put the screen near the rear view mirror because my automatic scan goes to that mirror and all I see is green.
John
'16 R-Pod 180 |
Posted: 09 Apr 2021 at 9:56pm |
I added towing mirrors from 1A Auto to our Frontier. I appreciate the additional visibility that the mirrors give me when they are extended.
Posted: 10 Apr 2021 at 7:25am |
The majority of states mirror requirements are that they reflect a view of the roadway of at least 200 feet behind the vehicle.
Personally this "at least" language doesn't make much sense to me. Any mirror with an outer edge that is set out as wide or wider than the trailer will do that, but could still leave a big (or infinite) blind spot. Seems like it should say something like "reflect a view of the entire roadway beginning at most 200 feet behind the vehicle". That would require mirrors to be set wide enough so that the view from the two mirrors overlaps withing 200 feet so the blind spot is shorter than that. But maybe I'm missing something. |
mjlrpod
Posted: 10 Apr 2021 at 10:44am |
All the times you have posted about these mirrors, I would look and say " nah, I don't need those", but I finally gave in. They are on order. Mostly i'm hoping they help me see when backing into a site. My back up camera is great for when i'm on the road |
podwerkz
Posted: 10 Apr 2021 at 2:19pm |
Posted: 10 Apr 2021 at 5:37pm |
Yeah I can just imagine the state governments' specs for rear facing cameras to meet blind spot requirements. Resolution, field of view, display sizes and daylight visibility brightness specs.
