  New Posts New Posts RSS Feed: Storage tanks sensors
Topic ClosedStorage tanks sensors
Ben Herman View Drop Down
Direct Link To This Post Topic: Storage tanks sensors
    Posted: 27 Mar 2021 at 10:21pm
Sometimes what I will do is wash our dishes in a basin in the sink, then dump the dish water into the toilet. As others have noted, much more of your water is used for washing than the amount that goes into the blackwater tank. It easy to use several gallons washing dishes, by adding that to the black water tank it better balances the load. The other plus is that as we drive towards home, the extra water in the black tank helps to liquify the solid waste  and typically makes it drain better to keep the black tank cleaner.
Direct Link To This Post Posted: 27 Mar 2021 at 10:12pm
Originally posted by rawest50
Fresh is translucent but gray and black are not. Not sure if you understand my question.
Not sure who you are addressing this comment to but I understand perfectly. As I said it is a better to start with empty gray and black tanks and monitor how much water you are transferring to them from the known starting amount in the fwt. If you do that then you can't overfill them and more importantly you won't overload your trailer which would most probably happen if you wound up with 2 full tanks and certainly happen if you had 3 full tanks. That's 750 lbs of water! Rpods are not really designed to have more than one tank full of water onboard.
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 27 Mar 2021 at 9:18pm
Is there another way to check the tanks?  That's already been answered: look down the toilet for the black and wait for the grey tank to back up in the shower.  Perhaps better, if you're using water out of the fresh water tank, when it gets empty and you need to fill it up, drain the black and grey tanks.  There is no way either one could be full, although the grey tank will be fairly close.
If you're on city water but don't have sewer hook ups, just learn about how long you can go without filling the grey tank.  I have a hard time making it a week.  Otherwise, watch the shower basin.  Tip: if the grey tank starts backing up into the shower, you can drain a few gallons and dump it down the toilet.  That will help flush the black tank as well as get the water out of the shower basin.
rawest50 View Drop Down
Direct Link To This Post Posted: 27 Mar 2021 at 8:41pm
2017.5 RPod 179
2017 Jeep Unlimited Wrangler
2 Weiner dogs
Great wife puts up with my BS
❤️ Thoroughbred Racing.
Direct Link To This Post Posted: 27 Mar 2021 at 7:54pm
Yep the sensors on the freshwater tank work the best too bad that you really don't need them there because the tank is translucent and you can see the water level. Oh well...
Direct Link To This Post Posted: 27 Mar 2021 at 7:20pm
My FW tank is also accurate. The gray is more accurate than the black for sure. Even after a thorough treatment and rinse which gets the black tank sensors working, it does not last because the first few days of use, especially when we are moving, ends up with the black tank sensors not working properly again.
Direct Link To This Post Posted: 27 Mar 2021 at 7:08pm
I have to agree about the sensors for both gray and black water but mine for some odd reason reads quite accurately for the FW tank.  Must have been a mistake at FR to have one that actually reads correctly.
Direct Link To This Post Posted: 27 Mar 2021 at 1:25am
Really, you should never count on those sensors to be accurate.  At best, they might be like the clock that's stopped: even that's correct twice a day.  You're cleaning and rinsing routine is great, but you know you're empty without looking a the lights.... and because they're right doesn't mean they'll stay right as the tank fills.
The sensors seem like a good idea, maybe even an essential, but they're not.  They are a cruel joke and totally unnecessary with a little experience and common sense.  Learn to live without them!  I haven't even looked at mine in years.
Direct Link To This Post Posted: 26 Mar 2021 at 9:31pm
I dumped this morning since we had another week camping. I added a lot of water before I dumped.
When we had the black water tank hose hooked up I turned on the black water sprayer. I left it on through the entire process that follows. I partially filled the tank 3 times after closing the valve. This was after the initial dump. I then rocked the Pod pretty good. You could hear the water sloshing in the tank. We had placed everything in the floor. Each time a few more pieces of paper came out. The 3rd time nothing but clear water. Checked the status on the sensor and it showed it was empty. I will let you know if that was a solution or just a sensor messing up. Gray water seems to be working fine.
2017.5 RPod 179
2 Weiner dogs
Direct Link To This Post Posted: 26 Mar 2021 at 2:34pm
Not to worry. You will typically put much more water into the gray tank than the black tank. I estimate that out of a 30 gallon fresh tank fill we put about 20-25 gallons in the gray tank and only 5-10 at most in the black tank. Even conserving water very aggressively (we can go a week plus on 30 gallons) a lot more goes to dish washing and showers than to flushing.
