  New Posts New Posts RSS Feed: No cold water, hot only
Topic ClosedNo cold water, hot only
Mstewart View Drop Down
Direct Link To This Post Topic: No cold water, hot only
    Posted: 22 Mar 2021 at 11:10am
Hi all,
I am a new Rpod owner (182G, 2017). We are in Texas and we are trying to check our camper before our first trip. We drained the fresh water tank before the freeze. After refilling, we have hot water only. Any thoughts on this mystery? There is no cold water at any sink or shower.
Thanks for your help!
2017 Rpod 182G
2019 Subaru Ascent
Direct Link To This Post Posted: 22 Mar 2021 at 1:57pm
Quick update, Now we have hot and cold water in the bathroom, nothing at the indoor kitchen sink, and hot only at the outdoor/garage sink. I have no idea....
2017 Rpod 182G
2019 Subaru Ascent
podwerkz View Drop Down
Direct Link To This Post Posted: 22 Mar 2021 at 3:31pm
When you open the cold water valve, do you hear the water pump running? Is the water system pressurizing when you flip the water pump switch on?
We need an idea where to start and what you have done or not done so far.
Direct Link To This Post Posted: 22 Mar 2021 at 5:33pm
Indoor kitchen sink most likely has a plugged screen at the outlet.  Unscrew and clean the screen.  As for the mystery of only hot water at the garage sink - the only thing that makes sense to me is that the line is pinched somewhere between the pump and the outlet at the garage.  If you aren't the original owner maybe the previous individual stubbed it off?  Follow that line from the outlet to the pump, you will certainly find the problem there.  By now you must have temps above freezing so I doubt you still have ice in your pex line.  Also, when the pump is on does it run for a bit and then shut off or does it continue to run.  If it continues to run you either have a pump issue or a leak in the pex.  If pex is leaking you should easily be able to spot water running on the floor or in the stow areas or leaking on the ground underneath.
Keep us posted and let us know what you have done up to this point.
