Overnight rest stops at Loves |
Post Reply | Page <1234 5> |
EchoGale
Topic: Overnight rest stops at Loves Posted: 09 May 2021 at 12:21pm |
Do you have a Maine destintation?
Julie
pedwards2932
Senior Member Joined: 21 Sep 2020 Online Status: Offline Posts: 338 |
Posted: 09 May 2021 at 12:19pm |
I know this is an old thread but we are getting ready for a Maine excursion. We are trying Harvest Hosts for 2 stops on our way there. They allow overnight stays just ask you to spend $ at the location.....usually a winery or beer garden so not an issue with me. We'll see how it goes. I used RV Parky to get an exit on the return trip that has a Cracker Barrel, a Walmart, and motels so I have all options available. RV Parky is a pretty handy app. I have been using Garmin's Basecamp to plan the route....it works pretty good but has a learning curve. You have to add weigh points if you want to go a specific route or it tries to take you the "shortest" route.
JR
Senior Member Joined: 31 Aug 2018 Location: Manistee, MI Online Status: Offline Posts: 345 |
Posted: 14 Mar 2021 at 3:03pm |
Yes you should run the slide out all the way if you are going to open it at all and do it in without stopping the operation once you have started it. If you do not complete the operation the shwinteck motors can become out of sync which then will operate the slide out not being able to fully open or close the slide out on both ends, leaving one end of the slide out either partially open or closed. Matter of fact it is better to keep the electrical switch engaged for a few seconds after the slide out stops moving. This a good way to keep the motors in sync. Hope this helps.
Jay
179/2019 |
pedwards2932
Posted: 14 Mar 2021 at 9:58am |
I will probably try Walmart or Cracker Barrel next time unless the Travel Center has RV parking. I was just thinking if it doesn't stick out any further than the wheel it shouldn't be a problem. We don't have to run it fully out just enough to be able to walk to the bed and access the bathroom. I would tend to park with a bit more room on the slide out side. My only fear is if someone parks too close on the door side and I can't get out.
podwerkz
Posted: 14 Mar 2021 at 9:10am |
If your slide-out doesnt hang over the next parking spot or into an access lane I would not see an issue either. If it does, especially around a busy truck stop in the truck parking area...my opinion is you are asking to have an impact.
I drove truck for 40 years and I can tell you...sh*t happens. Over the course of my career I was awakened many times when my truck was hit by another truck pulling in, backing in, backing out, or some other maneuver. Usually at night. It is not fun being awakened from a loud crunch and a violent shaking and then scrambling to get dressed and exit your vehicle only to see that the offending vehicle is leaving in the dark...no way to catch them or identify the exact vehicle. Looking at your rig and seeing damaged and bent bodywork and pieces of your vehicle in a pile on the asphalt. I'd be careful parking around trucks....is all I'm sayin. |
Posted: 14 Mar 2021 at 8:54am |
There have been a few stops I have made where it was tight enough that I did not extend the slide. However, most of the time, I do extend the slide. I try to find the most level spot I can. If there is a slope, I pull in so the vehicle is pointing toward the lower end so the jack can raise the front of the trailer, even while hitched. I use the Andersen leveler for side to side leveling. Then I lower the stabilizers using a drill-driver and socket. It is almost as fast as typing the description here. Then we can sleep well and the refrigerator is level for optimum operation. As others have said already, the slide does not extend out much past the fender so it is not a big deal to have it extended.
I did put reflective tape on the slide on the front and back right next to the flange so that if someone is pulling in next to us, the slide will be more visible. It is in an L shape on the bottom corners.
Posted: 13 Mar 2021 at 11:26pm |
I have always put the slide out at truck stops and no one has ever said a thing, for whatever that's worth. You're right, Pod slide-outs just don't extend far enough for anyone to care. A big ol' 4 foot slide out might be a different matter... TT
FJ Cruiser |
pedwards2932
Posted: 13 Mar 2021 at 9:22pm |
I had one other question.....it seems like the use of a slide out is considered a no no at these stop overs. But on my r189 the slideout doesn't extend past the fender.....so I can't see where that would be an issue? Also if the truckers have such an issue with RVers at truck stops they should take it up with the travel centers that actively court RVers and some even provide parking spots specifically for RVs
EchoGale
Posted: 13 Mar 2021 at 12:08pm |
Thanks for this I will likely do that!
Julie
podwerkz
Posted: 13 Mar 2021 at 7:31am |
Someone with an r-pod just booked a stay here for next weekend!
