  New Posts New Posts RSS Feed: 196 water heater bypass
Topic Closed196 water heater bypass - Event Date: 23 Feb 2021
tewjax View Drop Down
Direct Link To This Post Calendar Event: 196 water heater bypass
    Posted: 25 Feb 2021 at 10:38am
Thanks Pod People for the heads up but like Ricktoon says the antifreeze take up is at the water pump, not the water heater. Ricktoon, it looks like the 90ยบ elbow on the back of the vac is elbowed up instead of to the side so when the 2" flex pipe is attached it blocks the view and creates the cluttered look!
Tim & Diane, 2020.5 R-Pod 196
2007 Chevy Avalanche
2018 Honda Pilot AWD
2 Poms (Munson & Georgia)
Ricktoon View Drop Down
Direct Link To This Post Posted: 25 Feb 2021 at 11:35am
You may be able to move things around to get a better view. However, once you know where the valves are and the proper position it is pretty easy to change their position even in a tight space. I put a small knob and velcro on the panel so it would be easier to remove and replace in the future. Plan to do the same or use magnets for the water pump access panels as well.
Rick and Ellen B
2019 Chevy Colorado
2021 Rpod 196
