GlibGuy
Topic: Covers on inside lighting Posted: 14 Feb 2021 at 2:04pm |
I purchased my 2015 rPod 178 slightly used and it didn’t have an owners manual. So does anyone know the technique for removing the cover on the inside lights? It’s not apparent to me how they’re removed and I don’t want to crack or break them.
Appreciate it.
MICK
Posted: 14 Feb 2021 at 4:03pm |
I have same trailer, what owners manual:) As you look at lens it has plastic tabs, squeeze then hard together (difficult), at wide end of lens. The tabs will push in and lens will come down. There is a knack to it. It takes some pressure. I was surprised how much pressure it took. If you have plastic detail tools, you can use one of those (like a plastic flat screwdriver) to assist. Be careful not to break tab. 3-5 tabs on each lens.
GlibGuy
Posted: 15 Feb 2021 at 11:38am |
Originally posted by mcarter
I have same trailer, what owners manual:) As you look at lens it has plastic tabs, squeeze then hard together (difficult), at wide end of lens. The tabs will push in and lens will come down. There is a knack to it. It takes some pressure. I was surprised how much pressure it took. If you have plastic detail tools, you can use one of those (like a plastic flat screwdriver) to assist. Be careful not to break tab. 3-5 tabs on each lens. |
Difficult I reckon! I’m going to try heating them with a hairdryer.
Thanks for the information.
MICK
EchoGale
Posted: 15 Feb 2021 at 12:17pm |
I'd be worried about several things with heating them, most especially warping or discoloring them. I have a 2016 so I bet they're the same. I spread my fingers and grab the whole cover. While squeezing in, I turn the cover to get the notches into their slots. Once you get one down and get a look at it, it will become clear. Maybe start with an out of the way one to alleviate the anxiety about breaking. This is a little helpful https://www.walmart.com/ip/Dream-Lighting-RV-Interior-Led-Light-4-25inch-Dome-Ceiling-Light-Fixture-with-Switch-Cool-White/448124349?wmlspartner=wlpa&selectedSellerId=14634&&adid=22222222227327420870&wl0=&wl1=g&wl2=c&wl3=409710249771&wl4=pla-854805109574&wl5=9011560&wl6=&wl7=&wl8=&wl9=pla&wl10=118787474&wl11=online&wl12=448124349&veh=sem&gclid=Cj0KCQiA1KiBBhCcARIsAPWqoSou3Sg5S7qsmtV7jlZsY7v6UHZ0DN5v4gQpKnvGaUiKe6KeHQMBOcsaAmgdEALw_wcB
Julie
Pod People
Posted: 15 Feb 2021 at 5:54pm |
In our 2015 179, the sides must be squeezed and then the entire cover slid away from the center. Initially, I squeezed the sides and used a flat blade screwdriver between the lens and the center section to pry them apart gently.
squeeze and slide Vann
Vann & Laura 2015 RPod 179
Gebaldwin1
Posted: 16 Feb 2021 at 7:30am |
I found that putting a piece of masking tape on the plastic to serve as a pull tab works just fine. Pushing up on the plastic lens or squeezing it makes removal more difficult. The tape serves to rotate the lens without distorting it.
GMan
Lil' Bumpy - RPod 180
MissDaisy
Posted: 20 Feb 2021 at 7:17pm |
If it is the push button type, our lens cap just twists off. There are little tabs inside the lens cover that keep it in place within the fixture, which has three places cut out of the ring to let the lens come off. If you pull on the light, you risk pulling the screws out of the walls or ceiling. Simple twist is all it might need.
