yelvington
Topic: Replacing kitchen faucet Posted: 09 Feb 2021 at 6:59pm |
Hardest part of replacing ours was dealing with Pex. I went through a couple of press-on fittings before giving up and buying a compression ring tool. Well, that was the second hardest, actually. The hardest was reaching up there behind the sink! I finally figured out I could use the table as a platform. It's designed to be part of a bed, after all.
marwayne
Posted: 09 Feb 2021 at 10:58am |
Replaced ours with a Delta from Home Depot
Posted: 09 Feb 2021 at 9:59am |
+2 We also replaced our faucet when one of the handles broke off. Did the same as lostagain opting for a single handle unit from one of the big box stores. Did have to purchase a couple special unions that went from pex to what was coming out of the new faucet. And yes, we also made an additional trip to the hardware store to complete the job.
Posted: 09 Feb 2021 at 8:33am |
+1 to Pod People. We had to take the sink out to get easy access as the pex was installed all the way to the faucet. I cut it and installed a couple short supply lines to make the installation easier for that change and in the future. Replacing the sink was simple since it was a drop in sink and it needed re-caulking anyway. We got rid of the double handled faucet in favor of a single handle pull out.
Pod People
Posted: 09 Feb 2021 at 7:42am |
I have replaced the faucets on 2 different RPods. It is pretty standard fare -go to one of the big box home improvement stores and pick out a faucet that will fit in the space. Width of the base plate is the primary concern. the hot/cold supply lines generally will attach directly to the new faucet set. Access under the sink is pretty open and available. plumbing jobs always require at least 2 trips to the store!! Good luck Vann
Vann & Laura 2015 RPod 179
Medicine Wolf
Posted: 08 Feb 2021 at 11:24pm |
I have the standard bronze faucet....today it started spraying out of the front of the arched part like it had cracked and is spraying everywhere...wouldn’t mind an upgrade but don’t want something that’s a lot of work to install either...2010 rpod 151...Thoughts?
