Dimmer for inside lighting - all models |
rpod190 ![]() Newbie ![]() ![]() Joined: 07 Apr 2019 Location: Illinois Online Status: Offline Posts: 33 |
![]() ![]() ![]() ![]() Posted: 03 Dec 2020 at 1:37pm |
I couldnt take the bright lights in my rpod so I ordered this 12vdc dimmer which has a glass surface and you can touch or glide your finger on it to go from full to off and it remembers! The mod was easy to install for me. I first removed the switch panel to feel around and make sure no wires were behind the area i wanted the dimmer. I drilled a hole for the dimmer and removed the power lead feeding the inside lights. Put the dimmer inline to the switch and leave the indoor lights on. Nice to have control. Check you my mod lighting mod next. The dimmer is on Amazon here in black or white https://www.amazon.com/Wall-mounted-Dimmer-Switch-Brightness-Controller/dp/B07L3MT41G/ref=sr_1_18?crid=1NDEQ0SK8GR57&dchild=1&keywords=12v+dc+dimmer&qid=1607024082&sprefix=12vdc+dimmer%2Caps%2C183&sr=8-18 |
Wynnster
