  New Posts New Posts RSS Feed: Breakaway cable hook up
Topic ClosedBreakaway cable hook up
pedwards2932 View Drop Down
Direct Link To This Post Topic: Breakaway cable hook up
    Posted: 01 Nov 2020 at 12:07pm
When I purchased my RPOD the owner showed me how he connected the breakaway cable.  He had it attached to the safety chain hook.  I got to thinking about this and don't think it would work that way.  I suspect it needs to be hooked to the hitch independant of the safety chain. I would think you would want it slightly tighter than the safety chain so if it came unhooked it would put the activate the breaks.  Is that correct?  I am thinking I need to get a hook so I can attach it easily.
Direct Link To This Post Posted: 01 Nov 2020 at 12:34pm
You are right on both counts. Here is a nice video on how to set it up correctly.
https://www.youtube.com/watch?v=eubR3ssLiOM
Shane View Drop Down
Direct Link To This Post Posted: 01 Nov 2020 at 2:25pm
I use a D hook and attach it to the area where you would attach the safety chain S hook to the tow vehicle. Do not attack the break away to the chain itself, and make sure the break away cable is not to long either. It should be shorter than the chain that way it will break away, is it is longer than the chains it may not break away due to the chains being longer than the cable.
ENGINE 55,TRUCK 44,BATALLION 12
tcj View Drop Down
Direct Link To This Post Posted: 01 Nov 2020 at 5:50pm
Hey offgrid, thanks for posting that video.
2018 R-pod 180 Hood River Edition
