Axle replacement |
Sherbert
Newbie Joined: 19 Oct 2020 Location: Nevada Online Status: Offline Posts: 4 |
Topic: Axle replacement Posted: 27 Oct 2020 at 2:58pm |
I have a used 2020 rpod 189 with bent axles. I got a good deal on it. Would like to keep some of the money I saved.
So can I buy an aftermarket axle as long as I measure the hubs and spring mounts and the lugs correctly |
Posted: 27 Oct 2020 at 5:00pm |
Best to contact Lippert and buy a replacement axle for that trailer, plan on 1000 dollars with shipping. The axle will be around 600 plus. It will come complete with hubs and brakes. Trying to patchwork an axle in is not advisable.
SC for Huskers
Senior Member Joined: 22 Feb 2017 Location: Goose Creek, SC Online Status: Offline Posts: 144 |
Posted: 27 Oct 2020 at 7:23pm |
I would read all the different Axle posts and then consider going UP on load size of the axle. Lot of people with camber problems. Good Luck
Happy Traveling,
Tom 2017 172pod 2011 F150 STX |
Posted: 27 Oct 2020 at 7:30pm |
I agree with not mixing Lippert with non-Lippert parts, but I doubt you would get anything cheaper than Lippert anyway (or FR would already be buying it If your brake assemblies are good you could keep them and just buy a new bare axle, it shouldn't be a problem just buying that.
You could also take your trailer to a good trailer shop and see if you can get them to recamber your existing axle for you. Then, reinforce it with a piece of steel angle mounted under it and attached with 4 ubolts so it doesn't bend again.
Toyanvil
Senior Member Joined: 15 Feb 2019 Location: Bakersfield Online Status: Offline Posts: 157 |
Posted: 27 Oct 2020 at 7:45pm |
It should be under warranty 11 years on torsion axles. http://www.lci1.com/axles go to the bottom of the page "downloads" and click on Axle warranty sheet
Sherbert
Posted: 27 Oct 2020 at 7:52pm |
Just picked up a bare dexter axle.
Now all I have to do is transfer the electric breaks and everything else on the new axle. |
